ps pressure line - JeepForum.com
post #1 of 5 Old 10-22-2011, 09:25 PM Thread Starter
extremepsi
ps pressure line
whats the best way to change the pressure line 95 4.0 auto trans
extremepsi is offline
post #2 of 5 Old 10-22-2011, 11:18 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Your question is a bit vague. I would just buy a new one, open the gearbox end and let whatever fluid drain out, swap it, and top off the fluid. Is there specific aspect that puzzles you?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 5 Old 10-23-2011, 08:00 AM Thread Starter
extremepsi
it appears that the front grill has to be removed in order to get to the line
post #4 of 5 Old 10-23-2011, 08:05 AM
smoan
Are you talking about the power steering line. if you are i always just drop the steering gear box down its four bolts. the line has to be turned just right to fit up in there. you should take off the bumper cover. and if you can have one person on the bottom and one on top to guide you that makes it a lot easier. also if you get one bolt in towards the front you can kinda pivot it in
smoan is offline
post #5 of 5 Old 10-23-2011, 08:01 PM Thread Starter
extremepsi
dont honestly think ill be able to remove the bolt s for the gear they are very rusty
Broken Line from under the Oil Pressure Switch marcpuma YJ Wrangler Technical Forum 3 04-05-2011 06:11 AM
Lo pressure ps line, what size SteveJcoYJ YJ Wrangler Technical Forum 3 03-13-2011 05:34 PM
TJ Auto trans- Increasing Line Pressure TexanTJ TJ Wrangler Technical Forum 12 08-30-2010 12:48 PM
Brake help - OEM line pressure? ekim TJ Wrangler Technical Forum 12 01-01-2010 06:12 PM
A/C low line pressure? 2002RockHog TJ Wrangler Technical Forum 11 06-26-2005 10:06 AM
