Pros & Cons To Swap A Ax15 Or Nv3555 What It Is Better To Take Out Ba10/5 - JeepForum.com
post #1 of 4 Old 09-30-2007, 05:35 PM Thread Starter
Fed
I NEED TO CHANGE MY JEEP TRANSMISSION BA10/5 I JUST JOINED THE FORUM IAM FROM COSTA RICA, BEFORE PURCHASING A AX15 OR NV I WILL APPRECIATE ANY SUGGESTION OR RECOMEDATION. THANK YOU, PURA VIDA!!
Fed is offline
post #2 of 4 Old 10-02-2007, 04:44 AM
dmock
1984 CJ8
I went with a new NV3550 a couple of months ago. I am VERY happy with the results.
I used this thread as reference
http://www.jeepforum.com/forum/f12/build-thread-peugeot-ba10-5-nv3550-316455/
Good luck!
dmock is offline
post #3 of 4 Old 10-02-2007, 06:53 PM
lah2420
AX15 is probably easier, but I've read that the NV3550 is a much better transmission. I swapped to an 89 AX15 and an external slave assembly. It just takes a little more fabricating to get all the parts matched with the NV3550.
lah2420 is offline
post #4 of 4 Old 10-02-2007, 07:00 PM
pushead
No fabbing for the nv3550. I bought mine just over a month ago for 500 and another 500 for all the conversion parts from advanced adapters. I would say the swap work wise will be the exact same. Its just a matter of what you kind find for the price of the tranny. The nv is a stronger tranny with better gear ratios. Just do a search for each one. They are compared a few times on the site. For my swap i unbolted the ba10 and cranked up the new nv and bolted it in. It is a direct swap. For either swap you will have to change the input gear in your tcase. That is it in a nut shell.
Its not a jeep if it dont have 4wd.
pushead is offline
BA10 to AX15 swap question 88YJtoCJ YJ Wrangler Technical Forum 10 05-21-2009 01:11 AM
Ok guys tell me the pros and cons of a ZF swap Dmax5er YJ Wrangler Technical Forum 12 07-13-2008 08:22 PM
what modifications are needed to swap Ba10 for AX15 BA-YJ YJ Wrangler Technical Forum 13 06-23-2008 10:16 AM
D44 Swap in? pros N Cons? VABYJ YJ Wrangler Technical Forum 5 07-28-2007 09:30 PM
BA10 to AX15 swap? 1NastyZ06 YJ Wrangler Technical Forum 5 01-09-2006 02:48 PM
