Quantcast Pros/Cons of changing wheel backspacing and offsetting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Pros/Cons of changing wheel backspacing and offsetting
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 04-25-2009, 11:51 PM   #1
sprowley
sprowley's Avatar
Can someone elaborate on all the effects changing BS and offset have on the vehicle?
It would seem that the greater the offset, the more stress is put on the hub, but beyond that I don't know if there are any other effects (aside from the obvious tire fitment/rubbing at full steer changes)
I'm planning on getting some 16x7 alloys and 32 or 33 x 9.5 (probably the metric equivalent) tires, but I'd like to widen the stance of the Jeep a bit too. Any other ways to do this would be awesome, perhaps a set of axles I can find cheap that fit easy under a YJ and are just a bit wider, I don't think i want a full width axle though.
Thanks a lot guys
Sean
92 YJ Islander debadged and painted flat black on 32x11.5 Goodyear Wrangler MT/R Kevlars and Canyons, highlined fenders and extended TJ flares, 4.0L + AX-15, Aussie in the D30, TJ soft top, TJ full doors.Garaged and under the knife for frame-off repair! LJ stretch underway.
97 TJ Sport black on black with the YJ's MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
My Fuelly page (fuel economy and usage tracking)
sprowley is offline   Reply With Quote
Old 04-25-2009, 11:56 PM   #2
CreepyCrawler95
you can get a 1-1.5 inch spacer, more than tht though and i would just get more backspacing on the wheels
CreepyCrawler95 is offline   Reply With Quote
Old 04-25-2009, 11:56 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Why not an 8" rim with a 10.5" wide tire??? People have been running 3.75" and 4" back spacing for years with no issues.
rustywrangler is offline   Reply With Quote
Old 04-26-2009, 12:08 AM   #4
sprowley
sprowley's Avatar
unsprung weight.
I crunched the numbers and figured out that a few good MT tires in the 32 or 33 x 9.5 size paired with the right alloy rim weigh 4-10lbs less per wheel than stock tires and stock wheels. I like my fuel economy (20-21mpg city or highway) with my 4.0, and I want to go larger, but this is my daily driver as well not just a trail rig, and Soft 8s and 12.5" wide 33 MTs weigh something like 40lbs more per wheel than stock, which is a large reason people feel such huge power loss and fuel economy loss when they lift a Wrangler. That's an extra 160lbs of rotational mass on the driveline, which is nuts!
If I can keep the weight of the new 32s or 33s at or below stock weight, then I'll have no power loss due to the driveline. The only thing I'd have to watch would be the diff ratios, and after I get the new wheels I'll see if I need to change those as well.
Glock Forum
