proportioning valve leaking, broken bleeder? - JeepForum.com
post #1 of 3 Old 04-05-2010, 04:31 PM Thread Starter
offrdjeepfreak8
1987 YJ Wrangler
my proportioning valve for my brakes is leaking and i think the bleeder might be broken off. here's a picture of it:
and here's an image i found online:
you can see that this one has a little nub and mine does not. can anyone confirm this for me? thanks
1987 YJ Wrangler
4.2L l6, 5-speed manual, 3.5" Black Diamond lift, .5" Rough Country Shackles, 33x12.5 BFG A-Ts on 15x10 wheels, 48" Hi-lift
offrdjeepfreak8 is offline
post #2 of 3 Old 04-05-2010, 07:58 PM Thread Starter
offrdjeepfreak8
1987 YJ Wrangler
bump for info
1987 YJ Wrangler
post #3 of 3 Old 04-05-2010, 08:07 PM
idaholtby
My prop valve has what appears to be a "tin" cover over the part that your picture depicts. If you are leaking fluid from this port, then cover or not, this is a bad thing. I would suggest that you replace your proportioning valve if it is indeed leaking out of the end. It should not do that.
idaholtby is offline
Snapped Bleeder Valve jerseyrider1119 YJ Wrangler Technical Forum 16 04-26-2009 08:07 PM
Broke Bleeder Valve chupacabrah YJ Wrangler Technical Forum 13 03-30-2007 10:05 AM
broken bleeder valve, now what? Johnny World YJ Wrangler Technical Forum 14 04-26-2006 10:27 PM
Help - sheared my bleeder valve skifast1 TJ Wrangler Technical Forum 3 08-10-2005 12:00 PM
89 bleeder valve Heinbaugh YJ Wrangler Technical Forum 3 03-25-2005 06:55 AM
