Project "NO PLASTIC" Dash Build - Page 5 - JeepForum.com
post #61 of 68 Old 01-18-2010, 05:24 PM
1 ton yj
1 ton yj's Avatar
The gauges come with sending units that replace the stock jeep ones since they don't work with any aftermarket gauges.
1 ton yj is offline
post #62 of 68 Old 01-18-2010, 08:31 PM
92 Green YJ
92 Green YJ's Avatar
So, where do your windshield vents go now?
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #63 of 68 Old 01-19-2010, 01:34 PM
JeepsOLot
I'm getting Dan to make me a CYJ dash, just the left and center sections, I want to keep my Tuffy box. I'll be using the CJ gauges, YJ heater/vent controls, YJ headlight switches, the YJ hardtop switches and aux light switches, and the YJ dash pad. It'll be sweet when it's done, We already have the design nailed down and the dash is off to the laser cutter as I type. Dan is a great guy to deal with!!!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #64 of 68 Old 01-19-2010, 02:38 PM
freakmonkeydog
1987 YJ Wrangler
Originally Posted by Joe1167 View Post
things for sale:
tuffy lockbox consol- great condition!:
Still for sale? I tried to send you a PM, but it says your box is full
freakmonkeydog is offline
post #65 of 68 Old 01-19-2010, 09:58 PM
aar
Also looking to do this mod with Autometer gauges. Did you use mechanical or electric gauges?
Would either one work?
aar is offline
post #66 of 68 Old 01-20-2010, 08:05 AM
r7069c
Just in case you someone might need these. I know I did.
Might save you some time tracing wires.
r7069c is offline
post #67 of 68 Old 03-05-2012, 03:45 PM
nbryant
How did you connect your indicator lights? do you cut the connector and do a straight wire to wire connection?
nbryant is offline
post #68 of 68 Old 03-05-2012, 07:21 PM
EZAces
That would work. I would solder and heat shrink it my self. OH and holy thread res. 2 years since last post
EZAces is offline
"Project Naomi" TJ Build Whsperz TJ Wrangler Technical Forum 175 06-03-2013 02:13 PM
98 TJ Build- Project "Spiderman" SpydermanTJ TJ Wrangler Technical Forum 42 03-22-2010 01:34 AM
Do winch plates replace plastic "Jeep" frame cover? ZeroGravity YJ Wrangler Technical Forum 3 02-05-2010 12:29 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 08:32 PM
08 Sahara Rear Bumber "chrome" plastic removal PCHSahara JK Wrangler Technical Forum 9 09-08-2008 09:18 PM
