Quantcast Project "NO PLASTIC" Dash Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Project "NO PLASTIC" Dash Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-31-2009, 06:45 PM   #1
Joe1167
First off, i just want to say, that DAN IS THE MAN! if anyone is looking into a conversion like this, its great. you can keep almost all of your wiring, depending on the guages you run. DoubleD Fab is his work. Its great.
Here we have some before pics. I tried to paint it all black first, but still i longed for the plastic removal.
Then, i went looking for my gauges, and idiot lights. i went with these to keep wiring to a minimum, instead of going to all the CJ gauges. I decided on the Hot Rod Black II from autometer. they look sharp.
Then, the LED idiot lights. 2 greens for turn, a red for check engine, a blue for high beams, and a amber for 4wheeldrive. Any ideas on where i should put these? still undecided... as well with the kill switch and fog lights toggle...
Then, the wiring connectors, from caspers, which are water proof, and a few sets of waterproof splices.
Everything together (minus the steering column bezel, speedo and tach, and kill switch):
Then today.... this was waiting for me when i came home from school!
best part is being able to keep heater and lights control. LESS WIRING!
Its off to powder coat, then its demo time!
Also, anyone want to take the tuffy locking console off my hands? 60$ its great condition.
Joe1167 is offline   Reply With Quote
Old 03-31-2009, 06:49 PM   #2
smoke_20
That looks nice, can't wait to see it installed
Originally Posted by Urb4nTr0ll View Post
Honestly, I don't know who in the world put glue in a Lucas bottle, but it sure suckered me.
I have 4 x 4 on my YJ, but I'm not sure what it is suppose to do or if it is even necessary.
I'm mainly a street driver.
Any advice is appreciated, thanks.:thumbsup:
smoke_20 is offline   Reply With Quote
Old 03-31-2009, 06:52 PM   #3
capone1680
Looks great! Dan does great work.
capone1680 is offline   Reply With Quote
Old 03-31-2009, 07:01 PM   #4
simpkijd
That looks Great! Can you post a link to "Dan" or his shop I'd be interested in picking up one of those for myself.
One day my Jeep will be .....
[url]http://southsidejeepers.freeforums.org/[/url]
[url]http://www.militaryjeepers.com/[/url]
simpkijd is offline   Reply With Quote
Old 03-31-2009, 07:13 PM   #5
Joe1167
yea, you can pm him.
his JF name is Dislsmoke
cant say enough about his work.
Old 03-31-2009, 07:22 PM   #6
93jeepyj
That thing looks sweet I'll be watching your build. I just did a full cj dash swap and you made a wise choice keeping yj heater controls. I used the autometer gauges for my oil presure and volts and they worked out well, there pretty much an idiot proof install and I assume you got ones that work with the yj sending units so that should make it even easier for you. I like those indicator lights you got to where did you get them? I had to add one for the check engine light since the cj cluster doesnt have a spot for it. I wish I could find one labeled check engine so there wont be any bs when I have to go for emissions next time.
93jeepyj is offline   Reply With Quote
Old 03-31-2009, 07:39 PM   #7
capone1680
Here's a link to Dan's website:http://sites.google.com/site/doubledfab/
Old 03-31-2009, 08:06 PM   #8
Joe1167
www.jegs.com carries them. 5/16 indicator lamp.
and the gauges for the temp and pressure both come with their own sending unit, cause both were acting up, and i think they were the problem.
Old 04-06-2009, 09:48 PM   #9
simpkijd
I hope I'm not rushing you ,but have you had a chance to work on the install? I'm very interested on seeing how the new dash looks. This may be a summer project of mine....
Old 04-06-2009, 09:51 PM   #10
Tompatt
1987 YJ Wrangler
^^same here.
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Old 04-06-2009, 10:49 PM   #11
yjcrawlr
Looks great, only half of my gauges work after my 4.0 swap so I am going mechanical gauges where I can and electric for the rest my dash is about to get the home job of the dash swap. Alum. scrap drilled for some gauges with a cut out for a stereo and a idiot light or two.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
yjcrawlr is offline   Reply With Quote
Old 04-06-2009, 11:05 PM   #12
brandonse24
dude, dan is the man, i would love one of those dashes the "customer dash" off his website...
[B]Black Jeep Society Member #348[/B]
[B]Nightcrew #159[/B]
brandonse24 is offline   Reply With Quote
Old 04-06-2009, 11:54 PM   #13
cresencio
1987 YJ Wrangler
wow, thats amazing. i cant wait to see that in. hmmm now i want one
WWW.OFFROADJUNKIES.NET
My build
http://www.jeepforum.com/forum/f12/blues-87-yj-build-780995/
Just break it, that way you have to upgrade
cresencio is offline   Reply With Quote
Old 04-07-2009, 12:21 AM   #14
EZAces
EZAces's Avatar
Only question i have is what did it cost
EZAces is offline   Reply With Quote
Old 04-07-2009, 08:27 AM   #15
her94yj
hmmmm now this is like the 4th one of his dashes i have seen on here and each time i like more and more.. Dan a heads up one pissed off wife might be calling you soon to tell you to stop with the great ideas.. ok maybe more than one pissed off wife..... that would clean up my heap alot
His 89 4 inch super lift flat fenders,winch,8.8 lsd4:10s,44 front locked revolvers all 4 corners,soon to be building a half hard top now for the winter,
,94 4.0 stock gears, 4 inch RC 31x12. 15 procompXT,locked front,and rear
her94yj is offline   Reply With Quote
Glock Forum
