Project: LT1 Swap into '93 - JeepForum.com
post #1 of 205 Old 01-24-2010, 05:44 PM Thread Starter
HectorM52
Well guys, please welcome me and my buddy to the Jeep world. We're both newbies and will probably need tons of your help. I've done some research and I've been reading a couple of threads and I'm trying to compile a list of swap parts. If you guys can point me to any specific swap threads or specific posts that have lists of parts we would certainly appreciate it.
I'll try to get some pics of the Jeep ASAP and maybe a pic or two of the donor motor. Right now it's a '96 motor out of a Caprice but I'll be swapping some parts to turn it back into a '95 motor since those are OBD1 and I can program that PCM. The '96 motor is an OBDII and I just can't do as much with that year motor.
FYI, I've swapped a '95 LT1 & T56 into my '85 S10 so I'm real familiar with the "swap" itself and LT1 motors in general, but I know next to nothing about these Jeeps.
Looking forward to it, guys.
HectorM52 is offline
post #2 of 205 Old 01-24-2010, 05:46 PM
msprooch
Welcome, and you will love your jeep way more then your s10...you will probably sell the s10 so you can spend the money on the jeep.
msprooch is offline
post #3 of 205 Old 01-24-2010, 05:58 PM Thread Starter
HectorM52
Okay, I think I've narrowed it down to these two sets of adapters:
Advance Adapters 713087
I read on Summit that this mount requires a suspension lift. Though the dude below in THIS THREAD didn't mention the need for the lift. Anyone have any specific knowledge on this?
I also think this is a similar or the same mount...found this pic on this forum in the thread above. Please pardon my usage of this pic.
or
Advance Adapters 713007
Anyone have any opinions on these? Better to weld in? I am sure we can get it welded in but obviously the bolt-in kit will be much easier and we won't have to get the frame towed over to a welding shop.
post #4 of 205 Old 01-24-2010, 06:04 PM Thread Starter
HectorM52
LOL, thanks. Though I don't have to worry about spending MY money on the Jeep. It's a buddy's truck. I sent him the link so I'm sure he'll show up eventually.
Here's my truck - I'll probably never sell it!!
YouTube - LT1 T56 S10 at Road Atlanta
Wish I had some more recent vids, but that's about it for now.
post #5 of 205 Old 01-24-2010, 09:14 PM Thread Starter
HectorM52
Originally Posted by leftlanetruckin View Post
the jeep harness and the chevy harness do not splice together per say.
the only thing you need from the jeep harness is the switched power for the chevy ecm, thats it.
get the ecm output for the fuel relay, and either put that to the chevy relay and then to the jeep fuel pump, or put the ecm wire to the jeep fuel pump to turn it on. i used the fuel pump relay from the chevy.
the chevy will need a neitral safety switch, or just ground the wire IIRC, nd it will be happy. start in gear, but happy....
i think you are making the same mistake as others have, making it too complicated for yourself. follow the painless instructions, and where it says "12v in start", grab the wire from the column that is 12v in start, etc etc etc.
on the bulkhead fitting on the jeep, the plug is basically 2 plugs in 1. all the jeep motor/ecm wires you dont need. all the others are for lights etc, so dont touch them.if i remember right, the wires on the left hand side of the plug as you are looking at it in your hand, are the ecm ones. leave the rest alone!!
shoot me an email/im etc if you need any other help mate
martin
Just throwing this in here so I can remember it when it comes time to start wiring.
post #6 of 205 Old 01-24-2010, 09:29 PM Thread Starter
HectorM52
Anybody used these NOVAK mounts before?
post #7 of 205 Old 01-25-2010, 06:22 AM
tippmann243
whats up hector. i spend a lot more time on here then i do on ssf as of lately.
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #8 of 205 Old 01-25-2010, 07:53 AM Thread Starter
HectorM52
What's up?!
I guess I'll be a regular over here - hopefully some of the other "swap" guys will chime in and we'll continue to gather parts. Then we should be able to drop everything in and not have too long of a down time. That's the goal, anyway.
post #9 of 205 Old 01-25-2010, 07:58 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
I use them on all the ones I do with success.
They seem to last very well, and are adjustable for height etc too.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #10 of 205 Old 01-25-2010, 08:19 AM
rinking
I'm doing a vortec 350 swap right now. I've installed the Novak mounts! They seem to be pretty sweet. I went this route because most everything I've read, said to stay away from the cradle mounts. By the way, You've picked a very good place to get info! Good luck with the swap!
rinking is offline
post #11 of 205 Old 01-25-2010, 10:19 AM
bennymichael
Ok HECTOR. I have registered and will get the info on the specifics as well as some "before" pictures so that everyone can help and/or follow the progress. Should be a fun process.
bennymichael is offline
post #12 of 205 Old 01-25-2010, 10:33 AM Thread Starter
HectorM52
Email me some pics and I will put them up in my gallery.
post #13 of 205 Old 01-25-2010, 06:01 PM
Magneto
I used the Novak mounts on my 1991. Very nice. I don't care for the cradles - they're totally unnecessary and always in the way.
'69 CJ
'70 J Truck
'89 XJ
'91 YJ
Wife wants a Wagoneer...
Magneto is offline
post #14 of 205 Old 01-25-2010, 08:56 PM
GRUNT
Hector,
I too am in the middle of this swap. I subscribe to JP-Magazine and they recently had a series of articles about a project like this. Here are the links below. They, JP, even supply all the part numbers and experiences. Hope this helps.
Part 1
Part 2
-Allen
"No, but I did stay at a Holiday Inn Express..."
GRUNT is offline
post #15 of 205 Old 01-25-2010, 09:16 PM Thread Starter
HectorM52
Thanks, guys. I can see what you're saying about the cradle possibly being in the way.
I do like the adjustability of the NOVAK mounts - plus they are cheaper than the AA pieces!!
Project: Bumble Bee 5.3L V8 Swap! TrippinBimmer TJ Wrangler Technical Forum 16 04-25-2011 10:27 PM
Project Rubi Swap/Reconstruction YJ_Aaron TJ Wrangler Technical Forum 32 11-22-2009 12:42 PM
My J project swap plan KJFactor YJ Wrangler Technical Forum 9 11-18-2009 06:41 AM
Swap info for graduation project 95project YJ Wrangler Technical Forum 2 10-26-2003 07:54 PM
summer project 4.0 swap bjg YJ Wrangler Technical Forum 0 03-26-2002 01:37 PM
