#31 | ||
Yeah, It's A Jeep Thing!!
Thank you! I am sure by the time I get this done I will be saying the same thing!!!!! Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares |
#32 | |
Thank you. As far as the wiring goes, I took it all out and have it in a tub for right now. The PO had it all cobbed up to begin with so I am not totaly sure what my plan of attack will be. I no I will need to get the wiring harness for the V8 I have and then I may just get a new Jeep YJ wire harness, dunno. The tub came off pretty easy once we were able to get the body mounts all loose. The dash components all went in the trash since none of them really worked. Fellow member, coyote_94yj, will be making me a custom dash panel which looses basically the whole dash. Makes it look something like a CJ dash basically. The steering will get up-graded before the project is road ready. I have so much other stuff going on with it right now, I haven't given the steering too much thought. I hope to work on my axles this weekend and maybe get them ready to paint. I still have to find the 78' Eldorado backets/hardware. I will post new pics when I get some. Todd
#33 |
What year did your axles come out of? I reread and figured out your switching back to drivers side.
When you do all this are you stretching WB or anything or just going for a built stock style jeep?
91 YJ rebuild! Rush to get it driving/wheeling. http://ozarksjeepthing.com/c/index.php |
#34 | |
I am actually working on a PM for you with a few questions right now!!! Todd
#35 |
I'll respond as soon as possible. Heading out the door to evening class in a couple min.
#36 | |
Todd
#37 |
XJ on 37's
san fransisco was ok..... stuck in lodi,ca now, loading wed going to ontario,ca... ahhhh the things we do for money huh?
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#38 |
Not much happening this week on the project. I got the shop press last Friday and I ordered a complete set of set-up bearings for the D44 & D60 yesterday. I hope to get back to work on the axles next weekend.
Just wanted to give a quick update. Todd
#39 |
Not much going on again this week. I am getting ready to clean the frame up to paint and I was wondering what everyone's thoughts were on the stock shock towers. Should I replace them with a new shock tower that will work with the Blistein 5100's or should I just stick with the stock ones? Thanks for the suggestions.
Todd
#40 |
80-96 F250 front shock towers, $12 each at the dealer.
#41 |
Should I just go to a link set-up instead of leaf?????
I have been giving the suspension some thought and I saw a segment on Extreme 4x4 this past week and they did a link system on a Samari for under $1k. I already have 3.5" BDS springs from my SUA and it may be too high. What all would I need to go to a link set-up?
This is what I am thinking.... ~I am going to be buying new shocks regardless ~Instead buying a MORE trac bar I will be able to spend that money on the rear link se-up ~I will have to truss both axles ~I will have to get new coils & spring plates ~I can sell my BDS springs, new RE Anti-wrap Perches, new u-bolt plates, new u-bolts. I will be driving this about 50-70% DD so I would like to do it right if I end up going this. Thank you for your thoughts!!!! Todd
#42 |
So are you done yet?
![]() ![]() This thing snowballed quick. I really want to do something like this. Good luck man. I wish I could see in person.
I'm forever grateful to Speedycat and RnEmOvr for their generosity |
#43 |
If you sell your bds lift kit. Let me know how much you want for it. Nice thread by the way. Keep us posted.
#44 |
I'll take 2nd dibs on the lift, if things don't work for jeepcouple. And if you are going to sell them...
I'm just across the river from South Side. |
#45 | ||
Jeep Couple and otorahanga, I will let you guys know as soon as I know!!! Todd
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
