Project Canifornia Dreaming, My 1987 Worklog - Page 2 - JeepForum.com
post #16 of 19 Old 04-22-2013, 10:06 AM
Michaelgoesrawr
Originally Posted by ninjakid
Here.
And if it is 4B mocha brown metallic then I'd assume these paint codes would still be applicable.
That's good info. I think you should try and scan it and we can perdition to get it stickied. Lol.
The 231 like said above is a good case. Can take abuse pretty well and requires little maintenance.
If I had the funds and time to do a frame off I'd install an 8.8 in the rear if you can find one that matches your gearing and install an ax-15 with external slave. At least the trans so you don't have to fight with body clearances.
Michaelgoesrawr is offline
post #17 of 19 Old 04-22-2013, 11:06 AM
ninjakid
1987 YJ Wrangler
I don't quite have a scanner big enough unfortunately.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #18 of 19 Old 04-22-2013, 11:28 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Awesome thread, loved the tractor by the way! My jeep is an 87 with a sort of dark red... do you think this may be the Coffee color? It looks like a coffee bean...
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #19 of 19 Old 04-23-2013, 09:30 AM
Michaelgoesrawr
Well there's your problem. Haha. Sorry for some reason I was thinning it was a normal 8X11 or something.
