Project Advice for my '95 Wrangler - JeepForum.com
post #1 of 6 Old 09-11-2011, 11:31 PM Thread Starter
Chris9126
I bought it for the has mileage... Now I want to have the power side. I'm looking to do a V8 swap. I know a guy selling a 5.2L V8 out of a 1994 Jeep Grand Cherokee. I did some looking around & come up with on average 14-16 MPG highway & 11-13 city. I drive 20 miles a day just to go to school. 65 for 3/4 of the way. I have the automatic 4 speed, & won't change that. Last time I checked with my inline 6 I got 18 mpg. My YJ is a lot lighter than a Grand Cherokee though, & only has p235/75/R15 on it. You guys think it's worth it? Will the motor bolt right in, or will I have to get different mounts? I've only done motor swaps from S-10's to other S-10's.... Thanks a ton
BTW: With 3" dual exhaust, no cat's, would it help on gas mileage for the V8?
Chris9126 is offline
post #2 of 6 Old 09-12-2011, 12:53 AM Thread Starter
Chris9126
Or, will running it without cats mess with it?
post #3 of 6 Old 09-12-2011, 04:20 PM Thread Starter
Chris9126
Bump*
post #4 of 6 Old 09-12-2011, 04:21 PM
YJteen
Just get a high flowing cat and be legal with better sound and power. And I would expect slightly better mileage in a wrangler, but it is less aerodynamic so I wouldnt expect much more.
95 Rio Grande YJ. Power generously provided by 4 angry squirrels and a 20 gallon squirrel feeder. Sitting on 31x10.5 ATs with AR wheels
Yes I'm 20, Yes I like Jeeps, Yes I do not know everything
Originally Posted by GrandLaredoWJ
You should be fine with the axle setup, just as long as you don't beat on it as hard as you would looking at a Playboy magazine, the d30 and d35 should hold up.
YJteen is offline
post #5 of 6 Old 09-12-2011, 04:47 PM
TheNewbie
It's not even close to a bolt inswap. There is no bolt in v8 swap for a YJ.
You're looking at at least having to get new motor mounts and move over the whole computer and wiring harness. Then you will need to research if the fuel pump you have will work for that motor. Will the radiator work? What are you planning to do for a transmission and transfer case? Etc...
There are a lot of write ups on this swap. You should make sure to do your homework and start reading now.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #6 of 6 Old 09-12-2011, 08:38 PM Thread Starter
Chris9126
I was kinda hoping out of all the people on this forum someone would've already done this. But I'll keep lookin'
Project: Explorer V6 into my YJ! Any Advice? LFaJeep YJ Wrangler Technical Forum 6 09-18-2011 06:16 PM
advice on a TJ project TJe0454 TJ Wrangler Technical Forum 22 08-10-2010 10:59 AM
Need advice on project osmondmark YJ Wrangler Technical Forum 1 01-25-2010 07:16 PM
87 project, just starting and need advice. MuddyMules YJ Wrangler Technical Forum 7 11-13-2004 07:32 PM
