ProComp 130s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > ProComp 130s
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 03-29-2002, 05:11 PM   #1
sk8pr0
ProComp 130s
Ok, I just ordered 2 for 1 procomp 130s with the procomp wireing kit. Now I have a question for you guys. Will all the wireing diagrams be in there or do I have to try and find them online somewhere?
Thx, as always, for any help.
Red 93 YJ
30/9.5" tires
Lift and Lock soon (just need the $)
sk8pr0 is offline   Reply With Quote Quick reply to this message
Unread 03-29-2002, 11:00 PM   #2
highonthai
The lights contain no wiring diagram , Unless you bought the switch/relay kit.($15.99)
Just make sure you use a heavy guage stranded wire, a switch or relay with enough amp rating to run the number of ligths you are going to run.
Run the + side to the batt with a fuseable link and the - to a good ground.
If you just going for the two 130's=260watts/12 volts/
21.666666666666668 amps/0.5538461538461539 ohms.
Just get a switch thats rated over 22 amps DC.
highonthai is offline   Reply With Quote Quick reply to this message
Unread 03-29-2002, 11:05 PM   #3
sk8pr0
I bought the wire kit also, the pro comp one. Hopefully that will be enough to run 'em.
Red 93 YJ
30/9.5" tires
