-   -   problems when warming up (http://www.jeepforum.com/forum/f12/problems-when-warming-up-1451966/)
maxthegi 12-18-2012 09:52 PM
Just recently my YJ has started having problems at start up. Them temp outside is in the 40's. When I start the jeep and shift into reverse it will lock in but as I come to a stop and just before I shift my RPM's drop and it lugs.. when the RPM's come back up the vehicle locks back into gear... sometimes kinda hard. Any ideas?
maxthegi 12-18-2012 09:56 PM
also
Any links to threads about fluids? What oil/gear/ trans fluid/ etc people are using that works well. Anything that absolutely doesn't work well?
This is my first old jeep. Bought it in Japan so getting information and parts is difficult. I have to order parts from the states.
Mark05059 12-19-2012 04:51 PM
go back and fill in your jeep profile a little better.. OEM transmission could be many... etc. We cant help you much if you dont help us know what you have.
maxthegi 12-23-2012 03:54 PM
OK I have as much information on my profile as I can. I called Jeep to see what my original factory options were. Hopefully this will help to figure out the issue...
32RH transmission.
Someone said plugs. Going to pull them today if I can find a store here that carries the right ones. Any other suggestions would be appreciated.
maxthegi 01-19-2013 04:15 PM
Plugs did not work. They were wrong. The previous owner put shorter NGK plugs into the vehicle so I replaced the distributor, plug wires, and plugs. The jeep is still having issues in the cold with shifting. When I first start it and back out generally about the time I hit my brakes to put it in drive the RPM's just drop out. Within 2 seconds it comes back up and I will shift into drive. While driving sometimes in first gear it seems as if it slips out of gear as I get no power. After the jeep is warm I have no issues. Any suggestions?
Mark05059 01-20-2013 04:43 PM
My first suggestion is to check your transmission fluid level.
Que89YJ 01-20-2013 06:14 PM
It is probably your coolant temp sensor near the thermostat housing. That is the first place to start. I would also clean the throttlebody and the espcially the IAC.
http://www.jeepforum.com/forum/f12/q...-body-1262267/
maxthegi 01-23-2013 03:34 PM
I appreciate it. I will try cleaning this and let you know.
The time now is 05:36 AM.
