Problems with weber carb - JeepForum.com
post #1 of 3 Old 08-01-2013, 04:56 PM Thread Starter
yjrules
I installed a used weber carb on my yj lately and it's hard to start when the engine is warm. After I put in the weber it wasn't idling very well so I took it apart and cleaned it and it was much better. It starts right up when it's cold and runs really well, but if I shut it off after the engine is warmed up, then it's hard to start. I know some people say that some webers run too rich, so could that be my problem? By the way the carb is a 32/36 and I did put in a fuel pressure regulator set at 4 psi. Can anyone please help me out. Thanks.
yjrules is offline
post #2 of 3 Old 08-01-2013, 04:58 PM
rambo3489
Boiling gas? Otherwise probably too rich. Try starting it hot with your foot to the floor. That ought to lean it out some.
Also make sure your needle valve in your bowl isn't sticking closed. Mine was doing that. Had troubles sometimes starting it when hot for some reason.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 3 Old 08-01-2013, 05:43 PM
jbrown73
If you have set the lean best idle correctly & are having hard starting once warm the you are probably experiencing vapor lock (i.e. boiling gas). Search the forum for 'fuel boiling in carb'. I experienced the same issue & started that thread.
"The Constitution is not an instrument for the government to restrain the people, it is an instrument for the people to restrain the government....." - Patrick Henry
Originally Posted by Rproject View Post
The only thing I can say is to close your eyes. Seriously. If you close your eyes and pay attention to your finger tips, you'll be able to feel the nuts better and manipulate them easier.
jbrown73 is offline
