problems with manual transmissions? - JeepForum.com
post #1 of 7 Old 08-02-2002, 09:06 AM Thread Starter
vtmoonbeam
a friend on mine was asking if there are any known problems with the manual transmissions on the 1993 model. i searched a little bit, and couldn't find anything, but thought you guys might know. the cj in question was wrecked, so that might be the issue. but his daughter has been having problems ever since she bought it a year ago. thanks for you help!
vtmoonbeam is offline
post #2 of 7 Old 08-02-2002, 09:10 AM
RCHavok797
RCHavok797's Avatar
One thing though, if it's a 93 then it's a YJ or are you talking about 2 different Jeeps? I'm sorry I can't help I just saw that when I read your post.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 7 Old 08-02-2002, 09:20 AM Thread Starter
vtmoonbeam
sorry - brain fart on my part
no idea why i typed cj - its a yj. brain and fingers don't work together sometimes, i guess
post #4 of 7 Old 08-02-2002, 09:25 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
There are no known major problmes with the 1993 YJ manual trannies .. there are two choices, the AX5 behind the 4banger (2.5l) and the AX15 behind the 6popper (4.0l).
The AX15 is known to survive behind a slightly massaged Chevy 350 and I don't know enough about the AX5 to say much more than they keep goin' like the EngergizerBunny
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 7 Old 08-02-2002, 09:34 AM
UPnOVER
UPnOVER's Avatar
If she is having trouble shifting it is most likely the sink-rows. I have the AX-15 and 106,000 and their shot. With out more info it is hard to tell. Go have it checked. Could run $200-$3000. Good luck.
UPnOVER is offline
post #6 of 7 Old 08-02-2002, 01:20 PM Thread Starter
vtmoonbeam
i don't know many of the details either
she replaced the transmission not long after she bought it, and now the clutch has gone out. i'm thinking its related to the accident, if there isn't anything known to be wrong with the transmission. but then again, i don't know much about trannies.
thanks for your help everyone - i'll pass it along...
HAVE A GOOD WEEKEND!
post #7 of 7 Old 08-02-2002, 01:34 PM
jonabbott23
I had a 93 yj with the ax-15....and it went tits up on me....i had to re[lace it and i got one with 74,000 miles on it at a junk yard for $650....when it went out it popped out of gear and made a bunch of grinding noises then i knew i dont know if it helps but good luck
92' yj..RUST RED...6" PRO-COMP COIL CONVERSION..LOCK RIGHT LOCKERS F&R..WARN HS9500I...33"SUPER SWAMPERS...TAILGATE RACK...SOUND BAR AND SYE...UH MORE TO SAY BUT NOT ENOUGH ROOM
jonabbott23 is offline
'03 manual tranny problems ian-X TJ Wrangler Technical Forum 22 12-01-2010 11:24 AM
what manual transmissions mate to 4.0? JIBTEXHNKA YJ Wrangler Technical Forum 7 03-19-2009 05:05 PM
Calling all Manual Transmissions Iceman0502 TJ Wrangler Technical Forum 17 02-20-2008 09:30 PM
90 yj manual gearbox problems jeeplover27 YJ Wrangler Technical Forum 5 10-13-2005 02:16 PM
Manual Transmission Problems YellowTJ TJ Wrangler Technical Forum 5 03-07-2002 09:26 PM
