Problems with idling 1992 wrangler - Page 2 - JeepForum.com
post #16 of 26 Old 09-07-2011, 12:30 PM
Que89YJ
Ok, time to replace the CEL bulb then and see if it will let you check the codes.
IAC:
http://www.jeepforum.com/forum/f12/9...issues-894454/
Que89YJ is offline
post #17 of 26 Old 09-07-2011, 09:13 PM
tsalmeto
I've replaced quite a few TPS, it's code 24 and causes it to run rough and sputter. Borg Warner TPS from O'Reilly's limited lifetime guarantee, but you'll need it. After replacing the original factory TPS I've gone through 4 since February. The last time I replaced it, a few weeks ago, it didn't throw a code, but it stalled out when I was driving in front of my house. Exchanged it for another new one and that one was bad right our of the box. I put it in and it threw a code 24, and ran rough. Exchanged it for another new one and ran great.
I don't know how much one from the dealership is, but probably well worth it.
tsalmeto is offline
post #18 of 26 Old 09-07-2011, 09:18 PM
oldtime_ironman
Did you re-set the computer after you swapped the TPS each time? If not, then that was half the problem.
oldtime_ironman is offline
post #19 of 26 Old 09-08-2011, 10:48 AM
tsalmeto
Are you talking about disconnecting the battery cables and touching them together? If so, I did that.
tsalmeto is offline
post #20 of 26 Old 09-08-2011, 11:09 AM
oldtime_ironman
In that case, I'm truly surprised - you must have somehow gotten a really bad batch of them - amazing bad luck!
post #21 of 26 Old 09-09-2011, 05:04 PM
Que89YJ
Did you replace the bulb for the CEL?
Que89YJ is offline
post #22 of 26 Old 09-19-2011, 10:30 PM Thread Starter
JeepCreep454
Still haven't fixed the problem tried everything
JeepCreep454 is offline
post #23 of 26 Old 09-19-2011, 10:49 PM
moonshinefuel
I am thinking along the lines of post #6, a weakened fuel pump.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #24 of 26 Old 09-20-2011, 12:50 AM
HBJeepster
Im gonna stick to my idea, I hate EGR's so heres the trick, find the vaccum line that goes to the EGR, PLUG IT ( the vaccum line that is.) 100% sealed, with like a screw or wooden match or something similiar.... Please get back to me, when its something like that, most of the time it will fix it. The way you test an EGR is stick your fingure into the bottom of the egr house you will find hole just big enough for maybe your pinky, stick your your pinky in there, raise rpm's fast and kinda high, feel for the diaphram to move it should move very noticable if little movement then its bad then plug it until you can afford to buy that stupid A$$ $117.99 part... Oh and by the way it may not fix the idle while sitting still but the stalling or near stalling while moving, you should see a big difference... -HBJEEPSTER
HBJeepster is offline
post #25 of 26 Old 09-20-2011, 02:11 PM
Que89YJ
No egr on the MPFI. I asked earlier if you repaired the CEL. If not then you haven't tried everything yet.
Que89YJ is offline
post #26 of 26 Old 09-20-2011, 04:22 PM
tsalmeto
x2
The check engine light can really help narrow it down.
My CEL showed a bad tps and O2 sensor. Replaced both and runs great.
tsalmeto is offline
rough idle
1992 wrangler newheep YJ Wrangler Technical Forum 39 09-11-2011 08:14 AM
Will hardtop and doors from 1990 Wrangler fit on 1992 Wrangler? jacksprat1 YJ Wrangler Technical Forum 5 09-23-2010 08:22 PM
1992 wrangler brake problems mij3 YJ Wrangler Technical Forum 0 06-30-2008 07:01 PM
1989 Wrangler VS 1992 Wrangler HELP Danbo56 YJ Wrangler Technical Forum 23 01-19-2006 03:58 AM
1992 jeep wrangler problems Golddigger YJ Wrangler Technical Forum 18 01-18-2006 06:39 PM
