Problems with the 4 Wheel drive - JeepForum.com
post #1 of 6 Old 08-18-2011, 03:23 PM Thread Starter
michaelmorgan9
when i put the jeep on four wheel drive there is this cracking sound the starts (only on low speeds when i speed up it goes away)and when i turn the steering wheel all the way its impossible to move it!
its a 1990 jeep yj 2.5l
michaelmorgan9 is offline
post #2 of 6 Old 08-18-2011, 03:26 PM
Xpress
Does it have a locker up front?
All about that unibody life.
Xpress is offline
post #3 of 6 Old 08-18-2011, 03:29 PM Thread Starter
michaelmorgan9
nop the car is stock nothing upgraded at all, well not yet at least lol
post #4 of 6 Old 08-18-2011, 05:59 PM
rustybeater
is your 4wd working or does it seem like it is popping out if so look at the CAD. If your 4wd is working look at the u-joints on your front axle and drive shaft.
rustybeater is offline
post #5 of 6 Old 08-18-2011, 06:04 PM Thread Starter
michaelmorgan9
is there a way to check all of this while its on the ground and its not rolling or i have to lift it up and make the tires spin
post #6 of 6 Old 08-18-2011, 06:48 PM
rustybeater
to check the u joints you can do it on the drive shaft with it on the ground the ones on the front axle it would probably be easier to raise a wheel and rotate it back and forth and make sure it is all tight. To test if your 4wd is working I dont know I was having trouble with mine slipping out because of the CAD it was making a loud pop but it only happened under a load and then I could just tell the 4wd was not working.
4x4 , transfercase
four wheel drive problems ausra15 YJ Wrangler Technical Forum 8 11-15-2009 07:33 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 11:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 11:45 AM
4 wheel drive problems sihatch YJ Wrangler Technical Forum 3 05-30-2008 10:33 PM
4 Wheel Drive problems Hogmaster YJ Wrangler Technical Forum 1 06-24-2001 04:26 PM
