Problem to start - JeepForum.com
post #1 of 10 Old 08-27-2014, 01:53 AM Thread Starter
Stedoha
Problem to start
My renegade '92 start always at second or third attempt .
Do you have any suggestion?
Thanks
Stefano
Stedoha is offline
post #2 of 10 Old 08-27-2014, 07:25 AM
mike134
Could you clarify: Do you mean that your first attempt at starting the vehicle always fails? so you turn the key for 5-6 seconds, then wait, then try a second time and it starts?
If so, many people have this problem.
You should start by checking your fuel pressure at the fuel rail, Borrow a pressure gauge and connect it to the shrader valve on the fuel rail, it should be very easy to do. It should be above 30 psi while at idle. Turn the engine off, it should be above 10 psi after 30 minutes. Come back and tell us the results.
mike134 is offline
post #3 of 10 Old 08-28-2014, 02:05 AM Thread Starter
Stedoha
Yes this is the problem
Thank you for the help
Stedoha is offline
post #4 of 10 Old 08-28-2014, 06:16 AM Thread Starter
Stedoha
There is any possibility to increase the pressure? Or I need to replace the regulator?
Stedoha is offline
post #5 of 10 Old 08-28-2014, 07:05 AM
Old4X
1990 CJ7
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 10 Old 08-28-2014, 07:55 AM
mike134
I'd check the fuel pressure before doing the brain surgery since it is fairly painless, takes about 10 minutes. Go to autozone and borrow the fuel pressure gauge, its free but you have to leave a deposit.
It wouldn't hurt to replace the capacitors on the ECU like Old4x suggests anyway, if they aren't bad now, they will be in the future.
mike134 is offline
post #7 of 10 Old 09-02-2014, 12:12 AM Thread Starter
Stedoha
I just change the fuel press regulator, I still have the problem to start, 2/3 attempt .
More suggestion?
Tks
Stefano
Stedoha is offline
post #8 of 10 Old 09-02-2014, 12:17 AM
mike134
hmm, did you actually check the pressure? or just replace the part?
mike134 is offline
post #9 of 10 Old 09-02-2014, 12:42 AM Thread Starter
Stedoha
Humm, you catch me! I just replace....
Stedoha is offline
post #10 of 10 Old 09-02-2014, 08:17 AM
Que89YJ
You need to check the pressure. There are several pressure issues that it could be. 31 psi idle, 39 psi with the vacuum line disconnected at the pressure regulator. reconnect the line and turn the key off and it should stay above 20 psi for longer then 20 minutes.
Also use this thread and check your fault codes. Post what you get.
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
