problem idling in summer...help needed - JeepForum.com
post #1 of 3 Old 04-22-2001, 05:06 PM Thread Starter
Canube
now that the warm weather has arrived my 89 will not idle. It was fine all winter. Had this same problem last summer too. once the cold weather arrived last fall it ran like a charm!
I can't find any vaccuum leaks. What else could it be?
Canube is offline
post #2 of 3 Old 04-22-2001, 09:28 PM
TBirdzz
The same thing happens with my 87 YJ 4.2. When summer and winter come, I have to adjust the choke and idle. The choke pull off adjustment is the key to idle at start and the idle needs to be adjusted in four steps. Here is a link that may help. http://www.off-road.com/jeep/tech/258bbd/solvac.htm
87 YJ, 4.2 5 speed, hardtop, Lardeo model, for the past ten years.
TBirdzz is offline
post #3 of 3 Old 04-30-2001, 12:06 AM Thread Starter
Canube
Thanks for the info...i'll give the 4 steps a try!
Canube is offline
Idling Problem DVSYN YJ Wrangler Technical Forum 3 02-25-2009 09:01 AM
Idling Problem Clevs YJ Wrangler Technical Forum 5 04-05-2008 07:02 AM
Idling problem... Silver87YJ YJ Wrangler Technical Forum 1 01-07-2008 07:31 AM
SUMMER top solutions needed Fargo TJ Wrangler Technical Forum 13 05-08-2005 06:46 AM
Rough idling, dying while idling...tranny problem? MissLarramendy TJ Wrangler Technical Forum 7 07-25-2004 03:20 PM
