problem with 4x4 - JeepForum.com
post #1 of 3 Old 01-01-2002, 10:05 AM Thread Starter
blackjeep
problem with 4x4
since its winter now ive been putting my jeep in four wheel about three times a day. Recently i noticed that about 1 out of ten times it does not ingage fully. When i put it in it will grind when i go to pull out. I also noticed that every time i put it in there is a alot of slop in the shifter. do you think it could just be my linkage.
any help appreciated.
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
post #2 of 3 Old 01-01-2002, 11:17 AM
Trucidus Sum
What year Jeep do you have? Is it shift on the fly or locking hubs? I have a 92 YJ.. Shift on the fly isnt really "on the fly" You can do it while you are moving, but you must put the clutch in and let the engine rev down. Give that a try. And also, when you are in 4wd, the shifter always feels a little more sloppy. But if gets really bad, maybe you should take it in and have them look at the T-case.
Trucidus Sum is offline
post #3 of 3 Old 01-01-2002, 12:15 PM Thread Starter
blackjeep
sorry for not mentioning the year. It is a 95
It does moving or sitting
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 05:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 05:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 09:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 09:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 07:50 PM
