Probably asked a 1000 times - JeepForum.com
post #1 of 5 Old 08-18-2011, 08:20 AM Thread Starter
95YJ_Erwin
We have stripped down our 95 YJ and will be lining and painting next couple of weeks. Anyway, after several cans of Freeze Out, scrapped knuckles, some cursing, a set of easy outs, ... finally got all the Torx bolts out. I started looking for replacement Torx bolts, then realized I should not drink beer when planning on putting it back together
I figured I would replace (especially roll bar, seat belts) floor Torx (ones that get nasty) with hex heads. I can just match the ones noted above, but for future reference was wondering if anybody had ever put together a spread sheet or doc that showed "to replace Roll Bar Torx use this size Hex", etceteras? I would not mind replacing every Torx bolt in the interior with hex.
I did a search, but lots of hits on Torx / Hex and I admit I only looked through first 10 or so.
___________________________
95 YJ 2.5L - Stock for now - in process
95YJ_Erwin is offline
post #2 of 5 Old 08-18-2011, 08:32 AM
Redlightracer
If you run into problems with Torx bolts again , Weld a nut onto the Bolt then use wrench to get bolt out. Easy if and no broken knuckles. Sorry for the info late !!!
Redlightracer is offline
post #3 of 5 Old 08-18-2011, 08:34 AM
Que89YJ
If you are really into it:
http://www.quadratec.com/products/13019_208.htm
I personally take the bolts down to Ace Hardware and match them up with a hex grade 8 nut and bolt to replace it.
Que89YJ is offline
post #4 of 5 Old 08-18-2011, 09:20 AM
Louie4
This.
I wouldn't waste the time for the torx head bolts. Just get some good grade 8's by matching from ACE or Lowe's like Que said.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 5 Old 08-18-2011, 09:38 AM
Que89YJ
Now that I reread your question, I don't know? I thought there was a master list but I sure can't find it. The torque spec list is there. I wonder.... someone else like MAX, RUSTY, or JBolty might need to chime in!
Que89YJ is offline
Its been a while since I've asked for help... 89' YJ Junker YJ Wrangler Technical Forum 4 12-27-2007 08:28 PM
its probably been asked a million times....but.... brooksjeep TJ Wrangler Technical Forum 10 09-17-2007 01:14 PM
I know this has been asked...... BIG_KID TJ Wrangler Technical Forum 4 09-02-2007 09:23 AM
probably been asked a million times.....(go bigger than 35" tires on Dana 30?) MyRig is Yellow TJ Wrangler Technical Forum 5 04-15-2006 03:34 AM
This probably has been asked before... Maips TJ Wrangler Technical Forum 3 03-30-2005 07:22 PM
