#1 | |
Pro Comp Coil conversion Lift
I took my YJ out for the 1st time saturday after the Pro Comp Coil conversion install although it didn't have the flex of a Leaf spring kit it still out performed my previous Leaf spring kit.
I was able to go through the trail faster and easier than ever before rather than fight it over every rock and drop. One of my club members who drives a TJ said i flew through the trails with out issues. I think it made a world of difference over the Leaf springs i use to have.
#2 |
Pimp Hand
wait a minute.... let me get this straight.
did you say that your new coil suspension flexes LESS than the leaf spring suspension that was on there?! i would demand my money back!
___________________________________________ What is all of this talk of Savvily designed products?
#3 |
My marshmallow build http://www.jeepforum.com/forum/f12/my-marshmallow-build-873442/ |
#4 |
Yeah it has great travel but little flex but i can go over many more objects now than before i had to fight to get those freaking Leaf springs over rocks or even logs.
#5 | |
ummmmm i'd go get my money back if your coilovers aren't flexing as good as your leafs were. |
#6 |
If i knew how to post pix here i would show everyone 2 different pix of flex i had vs what i have now. I noticed that i had the drivers wheel tucked up in the drivers front fender with leafs but not with the coils there was about 4 inches between the fender and the top of the tire.
#7 | |
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#8 |
I think some of you are confusing coil springs with coilovers
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#9 |
what nooooooooo!!!!!!! that the lift i want Pro Comp Coil conversion hope its just some set up issue like arms being to short
will hope it all works out!!!!!!!!!!! this kit ![]() Last edited by CSCmrwizard; 01-26-2009 at 06:39 PM.. Reason: image |
#10 | ||
#11 | ||
Pimp Hand
#12 |
Here's some PIX
Notice how the drivers front tire is not tucked up under the fender like it should be. the 3rd picture is of the YJ sitting on an incline. ![]() ![]() ![]() |
#13 |
What keeps the tire from traveling up farther? Are the springs that stiff?
#14 |
Here is a leaf spring one to compare.
![]() Here is my friends tj. ![]() The genright pic looks like it is air shocks.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0 |
#15 |
It could be that the springs a stiff and the bushings were at around 30 degrees Temp wise.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
