preventative maintenance - JeepForum.com
post #1 of 7 Old 07-28-2010, 09:05 PM Thread Starter
Red_92_YJ
i have a 92 yj with just over 215000 miles on it. I use this jeep as my DD and am lookin for some basic repairs to make it more reliable. I drive this jeep around 300 miles from school to my house then 300 back to school once a month. my question is what would be the best things to do so i dont end up on the side of the road.
Red_92_YJ is offline
post #2 of 7 Old 07-28-2010, 09:17 PM
Rocky_Cosmark
Change all fluids often.
The obvious ones like oil and engine coolant,but you have to think about the diff fluids, and tranny fluids as well. None of those take a lot of time or effort but can go along way. I would also do simple things like make sure your tires are properly inflated, it says you have stock size tires so 225 235's could be around 32 psi and be fine. If its too high or low you could have problems in certain situations like a blowout for example. If you aren't familiar with changing some of those fluids im sure there are great write-ups on here for you to follow if you search. Im not sure where you stand mechanically just letting you know about the writeups.
Rocky_Cosmark is offline
post #3 of 7 Old 07-28-2010, 09:31 PM
moonshinefuel
A timing chain gone bad will strand you on the side of the road real quick. 4 cylinders I am more concerned about than 6 cylinders. Plus excess play in the chain, etc really can effect how it runs.
moonshinefuel is offline
post #4 of 7 Old 07-28-2010, 10:02 PM
Old4X
1990 CJ7
Hoses are and belts should be changed if you don't know their age ( or if more than 4 years old).
Keep the battery terminals and cables clean and treated with anti-corrosion spray.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 7 Old 07-28-2010, 11:49 PM
Mugzz819
General tune up on top of the fluid changes...change spark plugs, wires, distributor cap, rotor, air filter and fuel filter. That won't cost too much for everything and takes about an hour or so in the driveway.
Mugzz819 is offline
post #6 of 7 Old 07-29-2010, 02:34 AM
cubewhiz
Lube everything that has a zerk fitting. Total time would be about 5 minutes.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #7 of 7 Old 07-29-2010, 04:46 PM Thread Starter
Red_92_YJ
what about axles? Bearings?
Preventative Maintenance: Just do it! chitownjp TJ Wrangler Technical Forum 6 05-13-2010 10:21 PM
Preventative Maintenance Pipedrummer TJ Wrangler Technical Forum 17 12-09-2009 10:07 PM
Preventative Maintenance pat8942 YJ Wrangler Technical Forum 6 09-07-2008 07:38 AM
Preventative Maintenance Thread? canuck_bob TJ Wrangler Technical Forum 3 08-02-2008 12:04 PM
Preventative Maintenance helter YJ Wrangler Technical Forum 4 07-10-2002 11:57 PM
