Pretty sure this should be hooked up to something right? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Pretty sure this should be hooked up to something right?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-20-2014, 06:58 PM   #1
dander88
Is this supposed to be connected to that hose that's just dangling there. Sorry for the lack of knowledge.
dander88 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 07:10 PM   #2
Old4X
1990 CJ7
Nope
Clutch slave bleeder
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 07:18 PM   #3
dander88
Originally Posted by Old4X
Nope Clutch slave bleeder
thank you!
Unread 10-20-2014, 07:42 PM   #4
Old4X
1990 CJ7
No Problem.
Have you found the dangling vacuum line under your battery box yet?
Unread 10-20-2014, 08:18 PM   #5
dander88
No Problem. Have you found the dangling vacuum line under your battery box yet?
I haven't anymore clues. Or maybe it fell off..
Unread 10-20-2014, 08:55 PM   #6
Old4X
1990 CJ7
It has one of these stuck in the end (black, not white).
If you find it just hanging around, not hooked to anything, let it alone. It is supposed to be that way.
