Pressure Temp Switch - JeepForum.com
post #1 of 3 Old 05-29-2001, 07:17 PM Thread Starter
Joe R
I have an 87 YJ, and I'm trying to debug my temp gauge. For the most part it's pegged to the right all the time. I can't tell if it's the Sending unit, gauge or a short in the system, anyone run into this problem before & if so, can anyone suggest how to get an accurate reading ?
Thanks!
-Jr
Joe R is offline
post #2 of 3 Old 06-05-2001, 11:16 PM
wilhelm
joe r , i had the same problem with my 87YJ when i first bought it . it turn out to be the wire was off of the sending unit . the sending unit is on the cyl. head near the back , above the last exhaust manifold port . a purple wire is supposed to connect to it . if the wire is connected , see if it is grounded somewhere . if not maybe there is a something grounding the gauge cluster from behind the dash . good luck
wilhelm nj
wilhelm is offline
post #3 of 3 Old 06-06-2001, 12:07 AM Thread Starter
Joe R
Thanks for the suggestions Willhelm.
I did recently purchase a new sending unit.
I have yet to install it due to Finals @ school this week.
The connector to it seems to be fine, I still have yet to rule out a short behind the dash.
I found out some more info on the web: http://home.sprynet.com/~dale02/choke.htm
that my (possibly bad) sending unit could be messing with my idle via a relay. This link was an intersting find. (and could potentially explain some of my idle problems)
At the same website listed above http://home.sprynet.com/~dale02/diagnost.htm
I also found some more interesting information on the diagnostic connectors that will help me to determine what is messing with my choke motor & causing a bad idle. If I manually close my choke plate, I have a perfect idle. (just plain quirky)
Feel free to email me @ jrwired00@home.com
Thanks again for your response!
-Jr
Joe R is offline
Temp Gauge never comes up and oil pressure is always at max?? Nate M YJ Wrangler Technical Forum 11 01-22-2010 12:54 PM
temp switch mkleza YJ Wrangler Technical Forum 7 02-08-2009 10:09 AM
Temp switch for electric fan jeddy53824 YJ Wrangler Technical Forum 1 01-19-2009 02:54 PM
Question on Oil Pressure & H20 Temp JSimmons TJ Wrangler Technical Forum 10 11-29-2006 05:31 PM
oil pressure and temp gauge not working on a 95 fatboyq YJ Wrangler Technical Forum 2 04-19-2006 05:38 PM
