Quantcast Preparing for a offroad trip - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Preparing for a offroad trip
Old 06-02-2008, 07:12 PM   #1
Micah1234
Im new to my Jeep (MY first one) and im going offroading this week...How do you guys prepare your jeeps before and after your offloading trips.... Im gonna go topless and door less, should i take the carpet out? and when im done can i hose the interior down and let it drain out the drain plug holes, also how bout the seats? any information is helpful
thanks alot
Micah
Micah1234 is offline   Reply With Quote
Old 06-02-2008, 07:24 PM   #2
jgillespie
i leave the carpet out at all times, and let the rain/hose wash out through the drain plugs. i do live in gerogia so there is no rust problems.
make sure you have some moderate tools for any kind of repair, of course all depending on the caliber of off-road you will be. it would be a good idea to put the jeep up on jack stands after the trip and take the wheels off and clean the brakes, especially the rear drums so they don't rust or get rocks and other corrosive things in them.
good luck
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline   Reply With Quote
Old 06-02-2008, 07:45 PM   #3
93YJfalcon
Bring emergency rain ponchos (or at least one for the wife). I keep a waterbottle with the pop open top (or a dishwashing soap bottle full of water) with me to squirt the windshied. It works way better than the washer pump. Bug spray is golden. Cheap wet wipes for poison ivy laiden legs.
A happy woman = great wheeling.
Have a blast!
ROCK OVER LONDON... ROCK ON CHICAGO!
http://dirtyfabworks.com/gallery.htm
93YJfalcon is offline   Reply With Quote
Old 06-02-2008, 08:34 PM   #4
rammanriley
Lets see tools, some straps and a friend with his truck or jeep. Asfor the seats mine are vinal so i dont think a lil water would hurt them. (i hope not) a lil trick is get a gallon size zip lock bag for you registration and insurence as well as cell phone etc. to keep them dry.
rammanriley is offline   Reply With Quote
Old 06-02-2008, 08:47 PM   #5
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
I usually crawl under the Jeep and make sure everything drivetrain and suspension wise is still tight, and if it can be lubed it is. I check the fluid levels, top off the windshield washer fluid if need be. Check all lugnuts, make sure they haven't worked themselves loose. Basically I look for the surprise before it's a surprise. I do this both before and after the trip.
I carry a duffle bag of tools...wrenches, sockets, hammers, screwdrivers, all sorts of stuff. PB Blaster and WD-40 are always in there, as is a good size roll of duct tape...I prefer black. A set of jumper cables are always under my seat. Extra fuses in the glove box, for lights, cb and stuff. I have a shop light that plugs in to the lighter/outlet. I've been lucky enough not to need any of this stuff, but I have been able to loan some of these things to fellow jeepers. Oh and a hi-lift jack and a snatch 'em strap are a must too.
I also have a blanket, dog bowl and dog treats...just in case I bring my dog. I've even been able to help a fellow jeeper with the dog bowl and treats too.
After my last trip I will be adding a plastic tarp (to lay on when working under the jeep on wet ground..saw a fellow jeeper laying in a puddle while changing a drive shaft), a bag of assorted zip ties (just because you never know), and a cheater bar to put on the end of a wrench (also needed by the fellow jeeper laying in the water).
I'm looking for a spare rear axle shaft for the D35, but hoping I won't need it.
I'm sure there's tons more I could have with me, but I also rely on my fellow Jeepers to have what I may have forgot...heck we can't carry it all by ourselves, but together we can have it all.
Member of Jeeps Going Wild and IndyORV
My Jeep Pictures
Jeffro06 is offline   Reply With Quote
Old 06-02-2008, 08:58 PM   #6
sebastian22
Go Kings Go!
sebastian22's Avatar
if you havent already, removing your trac bars and disconnecting your swaybar will give you much better articulation off road and help you keep all wheels on the ground.
some other stuff i bring with me...
tire deflator tool, portable air compressor, tow strap, d-rings, tools, extra oil, transmission fluid, gear oil, lots of water, hi-lift jack, bottle jack, spare tire, folding shovel, lots of flashlights, sleeping bags and tent (just in case) lost of extra food and snacks, tarp, straps to tie all my stuff down, first aid kit, jumper cables, camera, and a pretty lady.
sebastian22 is offline   Reply With Quote
Old 06-02-2008, 10:29 PM   #7
TSEJEEPERS
tow points front and rear are manditory! Strap without metal hooks, fire extingusher, first aid kit, full size spare tire, CB radio, water and lunch. Assortment of tools and parts. Make sure everything is strapped down that includes yourself!
Hey have fun! You are not going alone right?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 06-03-2008, 12:22 AM   #8
Alabamaranger
Alabamaranger's Avatar
Also carry stuff like you are planning to camp. Food, water, toilet paper, lighter, flashlight, blankets. I glad it was not cold when we stuck two jeeps about 11:00 at night and worked on till 4:00 AM. Decided to sleep and wait for daylight to see what our next plan is.
Also tow cable / strap and snatch block. Be sure to have another vehicle or two to go with you.
Alabamaranger is offline   Reply With Quote
Old 06-03-2008, 01:30 PM   #9
MLJeeper
MLJeeper's Avatar
pretty much what everyone else said. LOTS of water, grease up everything, make sure the joints all appear in good shape, tools tools tools or ride with someone who is an independence freak like me that carries spare everything. Make sure your battery is secure, lots of problems from a bouncing battery including fires.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 06-03-2008, 01:43 PM   #10
djfred
Here is a PDF file i have uploaded to my server
http://softnation.org/files/Off-Road%20Pre-Trip%20Checklist.pdf
tells you what you will need when you go off-roading.
White 1992 YJ -- 4" Lift -- Dana 30 (front) / Dana 35 (rear) -- Tires 35x12.50x15 -- Black Bestop Supertop -- Magnflow Exhaust -- K&N Air Filter -- OBA
This is why you don't buy your early drivers a car at this age.
djfred is offline   Reply With Quote
Old 06-03-2008, 01:50 PM   #11
JpBill
1987 YJ Wrangler
Is that the right link? Not an off road list for me....hmmm
In the process of a 350 swap.
JpBill is offline   Reply With Quote
Old 06-03-2008, 02:11 PM   #12
sam.b.
2nd one down just click it to open it
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
www.kifourwheelers.com << Louisville Ky. based 4x4 club
sam.b. is offline   Reply With Quote
Old 06-03-2008, 02:20 PM   #13
Poke
Poke's Avatar
I keep a few road flares with me... not to use as designed. use them to start fires if you need to set up camp, wet wood is no match for a flare.... ask me how I know
mild mechanic that's overly ambitious
Jeep Envy
Originally Posted by Hashbrown View Post
The trouble with running is...by the time you realize you're not in shape for it, it's too far to walk back.
Complete YJ Besttop with hardware for sale. PM me.
Poke is offline   Reply With Quote
Old 06-03-2008, 02:36 PM   #14
flame0086
Depends on the calibar of the trail. I only go to distant places with another rig, and only go alone when I am a short phone call away for help.
check fluids, u-joints and any recent repair jobs.
Bring a tow strap, simple tool box, shovel and wd40 for when you get water in the distributer cap.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 06-03-2008, 03:35 PM   #15
Stimpdezracer
Besides the listed items above. I bring Baby Wipes!....
"Shes under powered, has little axles, doesn't flex that well, but she'll get there!"
Stimpdezracer is offline   Reply With Quote
Glock Forum
