Preferred "jack" point? - JeepForum.com
post #1 of 8 Old 08-02-2003, 05:30 PM Thread Starter
Shinner
Shinner's Avatar
Quick question....should be simple:
Where are the preferred jack points for lifting the rear of a YJ using a floor jack? On other vehicles in the past, I've always done it under the differential. Same for a Jeep?
Want to do the gas tank trick and figure it's gotta be easier to loosen the shield in the wheel well by taking the left rear tire off for more working room. Can also get a quick look at the brake pads too if I want.
His : 1992 YJ (Almighty 4 banger)
Hers: 2004 WJ Columbia Edition (4.7HO)
- Black Jeep Club V2.0 #37
- Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
Shinner is offline
post #2 of 8 Old 08-02-2003, 05:37 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
I always placed the jacks under the spring perch on the axle.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 8 Old 08-02-2003, 05:43 PM Thread Starter
Shinner
Shinner's Avatar
Maybe I should buy a set of jack stands too instead of just leaving it on the jack....saw em on the shelf when I bought the floot jack the other day, weren't that expensive. Shoulda done it.
Shinner is offline
post #4 of 8 Old 08-02-2003, 05:46 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Yeah, I just re-read you're original post and figured out you were talking about a floor jack. I would get a set of jack stands to keep it from moving or falling off.
Devious is offline
post #5 of 8 Old 08-02-2003, 06:36 PM
ga_mudder
It depends on what you are doing. If you want to life the whole rear end, jack under the differential and use jack stands under the spring perches. Lifting just one tire? Lift under the spring perches.
ga_mudder is offline
post #6 of 8 Old 08-02-2003, 07:38 PM Thread Starter
Shinner
Shinner's Avatar
Cool, thanks......I really only need to lift the one tire, so I'll go under the spring perch.
Shinner is offline
post #7 of 8 Old 08-02-2003, 08:30 PM
wm69
Havent' had a problem with it, but looks like jacking the whole back end up on the pumpkin would but a lot of stress on it. Spring perches are designed to hold up the weight of the vehicle; defferentials are not. Just something to think about.
wm69 is offline
post #8 of 8 Old 08-03-2003, 11:37 AM Thread Starter
Shinner
Shinner's Avatar
Yeah, that makes sense really...ought to be putting a jack somewhere under the frame.
Shinner is offline
Quick "Jack" question Timberman TJ Wrangler Technical Forum 2 11-28-2009 08:42 PM
Need to make final decision (is the "farm jack" over the Hi-Lift the best choice) phillsam YJ Wrangler Technical Forum 15 03-07-2009 12:45 PM
48" or 60" Hi Lift Jack for your TJ? blackout00 TJ Wrangler Technical Forum 13 04-17-2007 07:42 PM
Preferred 1" BL kopps94 YJ Wrangler Technical Forum 2 04-14-2006 09:39 PM
Ok, I have the guts to say it..."Stopping Point" urbanassault TJ Wrangler Technical Forum 38 01-20-2005 02:53 PM
