PPO wires or OEM don't know - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > PPO wires or OEM don't know
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 06-04-2013, 08:59 PM   #16
czjeeper
If it is wired correctly the ECM sees the compressor come on and uses the IAC to bump the idle higher.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 09:04 AM   #17
Siva283
Originally Posted by BIM9Bill View Post
I have an aftermarket AC unit in there now I did have a factory one in when I purchased the jeep last month.
The compressor blew up sending metal though out the system and it was cheaper to purchase a new from jeep air.
The jeep air unit doesn't have the wiring to connect to make the idle change. Is there an easy way to resolve this?
The Jeep air unit should plug into the factory wiring harness so yes it should have the wiring for it. If it doesn't you have the wrong unit.
Sent from my Galaxy S3 using JeepForum
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 09:28 AM   #18
Que89YJ
You need to have the 3 input controls for the ecu. Without it controlling the clutch you are going to run into some issues.
Look at this thread, I hope it helps:
http://www.jeepforum.com/forum/f12/a...stion-1093206/
Que89YJ is offline   Reply With Quote Quick reply to this message
