PPO wires or OEM don't know - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > PPO wires or OEM don't know
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 05-25-2013, 01:51 PM   #1
BIM9Bill
Hello again hello,
Second time poster, long time jeeper.
I am replacing the AC in my 1994 Jeep Wrangler YJ today. I also decided to remove the partially removed alarm from a previous, pervious owner (PPO).
I was able to get the bulk of the crap wires out and was able to still start the jeep .
I still have two unresolved wires / light holder thing. Attached are fantastic photos that may help figure out where they went. The two wires to the right are orange and black and attach to the wire loom. The others to the left are for a bulb, the blue thing is a tap from the PPO.
BIM9Bill is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 08:04 PM   #2
bigbossd1030
Originally Posted by BIM9Bill
Hello again hello,
If I am not mistaken the orange and black went to the cigarette lighter. The light holder thing is exactly that, a light holder. Most older jeeps that I have seen don't have the door pins anymore. But he tapped into the light for his alarm. It is probably like my remote starter I have now. The door has to open and close in order to set the starter, seeing as how this one was an alarm, it was more than likely to tell the alarm the door was opened. Anyway the light socket just mounts under the dash with a screw.
[COLOR="DarkGreen"]/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)[/COLOR]
[COLOR="Blue"]OFFICIAL JEEPER[/COLOR]
[COLOR="Red"]Any Jeepers in Edmonton, AB
I am on channel 33.[/COLOR]
I live, I ride, I am JEEP.
bigbossd1030 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 09:58 PM   #3
Firefyter-Emt
The lighter plug should be red and black. The orange and black should be for a dash light. Maybe the heater? Or is it to light the AC?
Get out a test light and see if it comes on with the parking lights as I think it will.
Or, if you can take some photos of the harness it leads to, I may be able to reverse trace it from there.
Firefyter-Emt is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 12:21 AM   #4
bigbossd1030
Or the light that is in the ash tray
l----L-[]lllllll[]-
Unread 05-26-2013, 08:03 AM   #5
Firefyter-Emt
Hmmm... never seen a light in the ash tray before.
As for the light, you know it bolts under the dash edge at the very left side, right? I would have to look, but I am pretty sure that outer wire on the lamp harness is the ground for the interior light's for the dash (not parking, but door switch lights)
Unread 05-26-2013, 08:49 AM   #6
Louie4
Everything looks stock but that tap on the wire.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 09:40 AM   #7
bigbossd1030
Orange and black cigarette lighter.
That socket is just a light socket for when the doors are open or you rotate your panel lights all the way up.
Pictures below of where I spliced into the cigarette lighter for my power plug as I didn't need a cigarette lighter.
l----L-[]lllllll[]-
Unread 05-26-2013, 08:35 PM   #8
BIM9Bill
Looks like the orange wire are indeed interior lights, as the get 12 volts when the lights are on.
Little update on the Air Conditioner installation.
Lot of "might as wells" attacked me this weekend, cleaned and painted rusted battery mounting stuff.
Found a leak in the heater core, found one at autozone and replaced it.
Now I am finishing up the Air, have to take out the radiator again to get to the condenser to put the hoses on correctly. Then electrical hookup.
Oh and I found a couple goodies in the heater.
Unread 06-01-2013, 10:03 PM   #9
BIM9Bill
AC Question. I have a 2.5L 4 banger engine.
I just got the AC up and running, blowing cold air and I am happy.
Except when idling, then the AC kicks on the Jeep wants to stall.
What should I look at?
Unread 06-02-2013, 01:24 AM   #10
bigbossd1030
What are your rpms at idle?
Sent from my iPhone, probably because I am bored at work.
l----L-[]lllllll[]-
Unread 06-02-2013, 12:59 PM   #11
BIM9Bill
bumped the idle from 700 to 1000-1100 and it works much better. Thanks for the idea/guidance bigbodds1030.
Bill.
Unread 06-02-2013, 04:54 PM   #12
bigbossd1030
Bill.
I think there may be more to it. The rpms should be around 700. There may be an underlying problem here. I don't have an ac so I am not sure what effects it has on rpms normally. But I am pretty sure it is drawing too much power. Hopefully someone with an ac can chime in in this.
l----L-[]lllllll[]-
Unread 06-03-2013, 10:07 AM   #13
Siva283
The A/C should trigger the idle to raise when you turn it on. Just like if you turn your steering wheel at an idle the RPMs will jump a little to keep the engine from stalling.
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 05:16 PM   #14
BIM9Bill
I have an aftermarket AC unit in there now I did have a factory one in when I purchased the jeep last month.
The compressor blew up sending metal though out the system and it was cheaper to purchase a new from jeep air.
The jeep air unit doesn't have the wiring to connect to make the idle change. Is there an easy way to resolve this?
Unread 06-04-2013, 06:45 PM   #15
bigbossd1030
Leave your idle a bit high? I guess it's not going to mess anything up, just be more gas is all. At least you know what the issue is.
l----L-[]lllllll[]-
