PPO wires or OEM don't know - Page 2 - JeepForum.com
post #16 of 18 Old 06-04-2013, 07:59 PM
czjeeper
If it is wired correctly the ECM sees the compressor come on and uses the IAC to bump the idle higher.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #17 of 18 Old 06-05-2013, 08:04 AM
Siva283
Originally Posted by BIM9Bill View Post
I have an aftermarket AC unit in there now I did have a factory one in when I purchased the jeep last month.
The compressor blew up sending metal though out the system and it was cheaper to purchase a new from jeep air.
The jeep air unit doesn't have the wiring to connect to make the idle change. Is there an easy way to resolve this?
The Jeep air unit should plug into the factory wiring harness so yes it should have the wiring for it. If it doesn't you have the wrong unit.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #18 of 18 Old 06-05-2013, 08:28 AM
Que89YJ
You need to have the 3 input controls for the ecu. Without it controlling the clutch you are going to run into some issues.
Look at this thread, I hope it helps:
http://www.jeepforum.com/forum/f12/a...stion-1093206/
Que89YJ is offline
