PowerTrax No-Slip ? - JeepForum.com
post #1 of 3 Old 11-07-2006, 03:16 PM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
PowerTrax No-Slip ?
I am installing a rear locker in a 87 YJ with the dana 35 with 456 gears, I dont no if I should go with the PowerTrax No-Slip or a Detroit soft locker? Which should I go with?
DaSham58 is offline
post #2 of 3 Old 11-07-2006, 03:45 PM
TSEJEEPERS
Replace the Dana 35. I ran a power trax no slip in my 30 and was happy with it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 3 Old 11-07-2006, 07:38 PM Thread Starter
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
Did you have to pull your ring and pinion? I seen where it said if you are running bigger gears you might have to pull them. I am running 456 in mine.
DaSham58 is offline
Powertrax No-Slip stedwest TJ Wrangler Technical Forum 13 04-01-2010 09:24 AM
powertrax no-slip jacksonjeeper TJ Wrangler Technical Forum 2 02-26-2009 07:13 PM
Powertrax No-Slip in d44 and d30 Tj_Justin TJ Wrangler Technical Forum 4 02-28-2007 11:26 AM
broken powertrax no-slip rajincajingt TJ Wrangler Technical Forum 3 03-30-2005 07:35 PM
PowerTrax No Slip Parajeeper TJ Wrangler Technical Forum 11 07-09-2002 08:45 PM
