powersteering high pressure switch? - JeepForum.com
post #1 of 3 Old 08-09-2010, 04:46 PM Thread Starter
silverslider
ok my powersteering feed line rusted through and had to replace it. in the process i also had to replace the lower portion of the return line also. but that is here nor there, the real problem is the "powersteering high pressure switch" came apart when i tried to take it off the old feed line. what the hell does this thing do? ive been hunting junkyards cause no aftermarket shop or even the dealerships have it. it also seems that just the 2.5 is the only one that has it.
so does it really "need" this to be drivable?
and in another thread someone said something about bleeding the system. how do i do that?
1995 yj 2.5 manual on 11.50 x 31's if that means anything
silverslider is offline
post #2 of 3 Old 08-09-2010, 06:19 PM
ritjobbie
You don't _need_ it. It senses when the PS pressure is high (meaning you are turning the wheel). Most of the time, nothing really special happens. But the 2.5 could possibly bog down or stall if you start cranking the wheel at low RPM (idle). The computer sees the low pressure signal at low RPM and just taps the throttle a little bit to keep from stalling.
Don't crank the wheel too much on the rocks at idle and you'll be fine. I'm not even sure that mine works and I've never stalled my engine by cranking on the PS.
Bleeding is cake. Get the front end up in the air. Open up your PS reservoir and slowly turn the wheel back and forth until no more bubbles come up. Fill the reservoir if it gets low as the air is bled out.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #3 of 3 Old 08-09-2010, 06:40 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
If you need one, the 2.5 XJ's also had them. That's where I got mine.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
Need some Genius! Oil Pressure Pump/Switch/Crank Bearings Replaced - Pressure Low??! malo8899 YJ Wrangler Technical Forum 1 05-20-2010 01:32 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 08:46 PM
Power steering high pressure switch ? KenF YJ Wrangler Technical Forum 7 12-18-2007 08:56 PM
Power Steering High Pressure Switch 1stTimeJeeper TJ Wrangler Technical Forum 3 08-13-2007 12:37 PM
Very high oil pressure BigD1634 YJ Wrangler Technical Forum 3 11-28-2001 06:40 AM
