Power steering pump noise? (How much?) - JeepForum.com
post #1 of 6 Old 05-23-2011, 12:37 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
I expect some noise from my power steering, but how much is too much? I can hear it over the engine it almost sounds low on fluid. COuld I have air in the lines? I read to jack up the front end and turn from side to side like 20 or 30 times then check the level. The noise is louder than the engine its not a squeeling just almost like a growl....enough to annoy.
Would a new pump fix the problem?
Chris Aunchman is offline
post #2 of 6 Old 05-23-2011, 04:15 PM
Brown Dog
Vendor
Brown Dog's Avatar
New pump is the only fix to the problem
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 6 Old 05-23-2011, 08:19 PM
MoparFreak69
You should not hear any noise from your power steering pump, with the exception of holding the steering wheel hard at the wheel stops and then its only normal to have a very slight growl. Sounds like it is time to replace that pump.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 6 Old 05-23-2011, 08:54 PM
bharris68
With luck - this will help - I did this write up a few weekends ago:
http://www.jeepforum.com/forum/f12/h...-hose-1214933/
bharris68 is offline
post #5 of 6 Old 05-23-2011, 09:29 PM Thread Starter
Chris Aunchman
1987 YJ Wrangler
Yea that is what I was thinking replace the pump, any after market ones that are really quiet or are they all about the same?
post #6 of 6 Old 05-23-2011, 09:34 PM
bharris68
"CarDone" fully remanufacturers their pumps. I have had good luck so far with theirs.
TJ needs help! Noise after replacing power steering pump and belt Tevisrocks TJ Wrangler Technical Forum 11 04-01-2011 12:32 PM
Power Steering pump leaking pink liquid - can the pump be fixed, or replaced? Sparty TJ Wrangler Technical Forum 10 01-13-2010 11:29 PM
Power Steering Pump Pulley Noise brrempel TJ Wrangler Technical Forum 5 07-18-2008 10:14 PM
Changed Power Steering Pump Now Have Noise bige2533 TJ Wrangler Technical Forum 1 04-29-2008 10:37 AM
power steering pump noise 72cj5er YJ Wrangler Technical Forum 7 03-28-2007 10:45 PM
