power steering problems - JeepForum.com
post #1 of 6 Old 06-22-2016, 09:32 AM Thread Starter
judsjeep
I just replaced the power steering gear box in a '93 YJ and it's not smooth. It feels tight and like it hits a bubble then releases. Could there be a bubble in the line? Is there a way to bleed it out?
judsjeep is offline
post #2 of 6 Old 06-22-2016, 10:02 AM
TSEJEEPERS
Yes it could still have air in the lines.
To bleed it, open the hood and check the fluid level add if it is low.
Start the engine and slowly turn the steering wheel left to right and back again. Do not turn the wheel completely lock to lock. Check the fluid level and fill as necessary, until it remains steady and no more air bubbles.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 6 Old 06-22-2016, 10:08 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I've always turned lock to lock. Why are you saying not to?
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 6 Old 06-22-2016, 10:12 AM
TSEJEEPERS
That is what the book says. Really not sure why.
When I did mine I did end up going lock to lock with no problems.
post #5 of 6 Old 06-22-2016, 11:16 AM
Mr.B
Mr.B's Avatar
Hmm. Maybe initially when you first start, there isn't enough fluid in the pump. So you could damage it. That's all I can think of.
OP: you may have to do this for a while until all the bubbles get out. If its still happening, you might have other steering issues.
Ham license:
Everyone is Welcome
Mr.B is offline
post #6 of 6 Old 06-23-2016, 08:52 PM
timatoe
timatoe's Avatar
AGR says turn it lock to lock 5 - 20 times without the engine running. Fire the engine and watch to see if the fluid level drops, if it does there's air trapped in there. The only way you're getting it out is to keep cycling it back and forth. AGR does say not to "hold" it at the stops when running.
If you just replaced the box and didn't do this or some type of cycling, I'd nearly guarantee you've got air trapped in there.
timatoe is online now
