Power Steering! :D Conversion. :( - Page 2 - JeepForum.com
post #16 of 63 Old 04-06-2013, 08:02 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Then you're going to need a remote reservoir.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #17 of 63 Old 04-06-2013, 09:33 PM Thread Starter
caoboy
Copy that sir
caoboy is offline
post #18 of 63 Old 04-21-2013, 11:16 AM Thread Starter
caoboy
http://www.ebay.com/itm/91-95-Jeep-W...6c06d4&vxp=mtr
I pulled the trigger on this. I'll start looking for a reservoir throughout the week.
caoboy is offline
post #19 of 63 Old 04-21-2013, 11:18 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like a plan. If you need help installing it, I only live down the way.
Luck Favours The Prepared
Anticanman is offline
post #20 of 63 Old 04-21-2013, 11:22 AM Thread Starter
caoboy
Sure thing, Nick!
caoboy is offline
post #21 of 63 Old 04-21-2013, 07:06 PM
Destr0
I used the pump with the res on it in my 94- bolted right up no clearance issues at all. Used XJ gearbox and lines too.
~Kevin
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #22 of 63 Old 04-22-2013, 06:44 AM
Mr.B
Mr.B's Avatar
~Kevin
Do you have pics?
Ham license:
Everyone is Welcome
Mr.B is offline
post #23 of 63 Old 04-22-2013, 07:04 AM
kostyanj
I really hope that's true about being able to use the pump with attached reservoir. I have one sitting in my garage from a 4.0 but with a v-belt pulley. So if I change the pulley and put a drop pitman, I should be good to go?
kostyanj is offline
post #24 of 63 Old 04-22-2013, 07:45 AM
Destr0
I do not have any pictures at the moment but i will see if I can get some and post them tonight when I am working on the beast. I can't remember off hand what Jeep (XJ or YJ) my pump came off of- it was in a friends box of spares and I said I needed on so he gave it to me. The gearbox I know was from an XJ because I pulled that myself.
Right now I am not sure I can get my hood open because my Jeep is suspended from a gantry on chains so I can swap my front springs (I broke a front bastard pack so bought some Fabtech 3.5" replacements).
Cheers!
~Kevin
1981 CJ7 SBC 350
Destr0 is offline
post #25 of 63 Old 04-22-2013, 10:02 AM
Mr.B
Mr.B's Avatar
What I do know is that the 2.5L with MPFI, came from the factory with a remote reservoir.
When I did my conversion, I pulled this pump off a '86 XJ, right after I took this pic. It wouldn't fit on my Jeep.
Ham license:
Everyone is Welcome
Mr.B is offline
post #26 of 63 Old 04-22-2013, 02:04 PM
Lemoore-on
Yeah, there's no way that would have fit on my 92 with MPI 2.5. It bearly fit without the reservoir.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #27 of 63 Old 04-29-2013, 09:16 PM Thread Starter
caoboy
Ok so I've received 1 of apparently 2 packages. The pump, and 2 lines. Still waiting on the actual steering box (you know, the part that costs the most money out of all this..) to arrive. I guess the people I ordered from like to cut down on shipping charges by stuffing things in flat rate boxes...and of course USPS' tracking system isn't the best, all I can see in the 'details' is that the second box has departed Philadelphia, and that's it.
caoboy is offline
post #28 of 63 Old 05-04-2013, 06:12 PM
az_zoner
I'm also in the process of doing this upgrade. I have a 91 that is without power steering. I am installing a dodge gear box that I got from a local JY. Do I need to purchase a new power steering Pitman arm or can I use the arm that is on my manual steering box?
thanks,
cb
az_zoner is offline
post #29 of 63 Old 05-05-2013, 12:12 PM
Mr.B
Mr.B's Avatar
I'm not speaking from personal experience, because when I did the upgrade, I used an XJ box that had the dropped pitman arm already attached. But from what I have read here, you will need a PS pitman arm.
Ham license:
Everyone is Welcome
Mr.B is offline
post #30 of 63 Old 05-05-2013, 05:14 PM
az_zoner
Thanks, I'll start looking around for P/S one.
At what point in lift height do you need a taller pitman? Mine, now that it has settled in is about 2.75" over stock. Everything else is stock.
cb
az_zoner is offline
