Power Steering! :D Conversion. :( - JeepForum.com
post #1 of 63 Old 04-05-2013, 09:04 AM Thread Starter
caoboy
Power Steering Conversion 2.5L (completed!)
Ok, I'm about to bite the bullet on this conversion.
I have a 2.5, no AC/PS.
As far as I know, I need the pump, pulley, high pressure/return lines, gear box, reservoir, and new serpentine belt.
I want to get over to the JY today and start hunting down parts.
The main thing i'm looking for would be the gear box. I know that doesn't matter as an XJ or YJ will work.
The pump, is only 75 before the core charge from a shop. No pulley. Can I use the old idler pulley that's on the rig now?
Also, with the pump, do I need a different bracket to mount it? That, I can't remember if it is confirmed on one of the main PS conversion threads here.
Lines I can get new from the shop.
Reservoir I'm hoping I can find one that will work. If I can find a 2.5 XJ I should be good to go on ripping everything out of it
Other than that I think I should be set, right?
(thank you guy in sacramento area with the PS conversion thread...you're helping me pull the trigger on this one!)
caoboy is offline
post #2 of 63 Old 04-05-2013, 09:44 AM Thread Starter
caoboy
Mr. B's power steering thread is the one I am referencing.
caoboy is offline
post #3 of 63 Old 04-05-2013, 09:56 AM
PA_YJ19
U cannot use ur current pulley, go to the junkyard and get a pump that already has the pulley attached off of an xj, steel the lines too if they r in good shape. Everything should bolt right on to urs. If u want I upgrade the gearbox, get one off a v8 Durango instead I the xj. Otherwise u can take everything right of the xj n out it on urs. Only thing ull need to get at the parts store is a new belt and some ATF to fill it up with. Also it doesn't need to be from a 4 cylinder xj, u can take it off a 6 cylinder. They all use the same pump, pulley, and gearbox.
PA_YJ19 is offline
post #4 of 63 Old 04-05-2013, 09:58 AM
lutzke21
I don't recall using a different bracket, I think I bolted my pump in place of the idler. But it's been nearly ten years since I did mine...and I can't refresh my memory by looking at it currently. I also ended up using a remote res from a GC as my donor pump was only a pump.
+1 on the Durango box. Lose a bit of radius, but gain some power. Stock box will wearout with bigger tires.
When I was done though, I fricken loved it. Sooo much nicer.
Good luck.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #5 of 63 Old 04-05-2013, 10:06 AM Thread Starter
caoboy
I recall reading that the 4.0 pumps had the res attached. Is that not true for all the pumps?
caoboy is offline
post #6 of 63 Old 04-05-2013, 11:25 AM
PA_YJ19
Xjs all have the reservoir attached, yjs did not. U can use the ones with the attached reservoir on a yj tho, it's really not worth the trouble to take it off unless u already have the stock yj reservoir. The pump/pulley will take the place of ur old idler pulley that sat there, it is also used to adjust the tension of the belt.
PA_YJ19 is offline
post #7 of 63 Old 04-05-2013, 01:29 PM
dadstoy
Good luck.
I did the Durango swap and lost radius also. Put a pitman arm from a GC in place of the stock YJ pitman arm and got most, if not all of my radius back.
dadstoy is offline
post #8 of 63 Old 04-05-2013, 06:42 PM
timatoe
timatoe's Avatar
caoboy, if you haven't already check out NorcalJeepers.co
All of us remotely close to you are over there, including Mr.B. Also there's a guy in Lathrop parting out a XJ that you may be able to get a lot of what you need from.
timatoe is offline
post #9 of 63 Old 04-06-2013, 12:40 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
We have some power steering stuff around. Don't buy from the guy in Lathrop, he's a crook.
Luck Favours The Prepared
Anticanman is offline
post #10 of 63 Old 04-06-2013, 10:13 AM
timatoe
timatoe's Avatar
You have a PM.
timatoe is offline
post #11 of 63 Old 04-06-2013, 10:36 AM Thread Starter
caoboy
Nick what do you have? Name your price!
caoboy is offline
post #12 of 63 Old 04-06-2013, 10:39 AM Thread Starter
caoboy
I just hopped on board over there. Thanks for the invite
caoboy is offline
post #13 of 63 Old 04-06-2013, 11:12 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Dan has all the pulleys to convert and has a lead on two boxes and two pumps. He's converting another (his third) Yj to power steering for the trail.
post #14 of 63 Old 04-06-2013, 04:03 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Do you have Multi-port fuel injection on your '91? If not, you can get by with a pump reservoir combo.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #15 of 63 Old 04-06-2013, 04:14 PM Thread Starter
caoboy
I do have mpfi. Its a 91 2.5
caoboy is offline
