Quantcast Power Steering Conversion? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Power Steering Conversion?
Old 09-16-2006, 10:44 PM   #1
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I'm looking for a write-up on a power steering conversion. I've searched, but couldn't find one for a YJ. If there isn't one, maybe someone who has done it could give me some tips and ideas of what it will cost. I'm not looking for high performance, just something better than manual steering. If there is something from different vehicles that will bolt on, that would be fine. There are lots of junkyards around here, but the Jeep yard thinks they are selling new parts.
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 09-17-2006, 10:14 PM   #2
Mr.B
Mr.B's Avatar
I went to Kragen today and got an estimate. Here's the breakdown.
Power steering pump $80
Core charge $50 (don't have one to return)
Power Steering Pulley $25
PS hose $24
Power steering hose $17
Gear box $168
_________________________
Total $364
The kid at the counter said he thought I could bring in my old manual gear box for the core charge. If he is wrong, it's another $125.
There's got to be a cheaper way.
My Jeep
KB6NQT
Everyone is Welcome
Old 09-20-2006, 10:15 PM   #3
Mr.B
Mr.B's Avatar
The Jeep junkyard is going to want almost as much as Kragen wants for rebuilt parts. Besides the '98 Durango, is there another gearbox from another vehicle that I might find at the pick and pull? And how about pumps? There sould be one that will bolt on. They're pretty much all the same, aren't they?
My Jeep
KB6NQT
Everyone is Welcome
Old 09-21-2006, 01:54 PM   #4
ChevDog1
I bought an entire 1987 cherokee for $400.00 for the drivetrain. It turned out that the power steering was a bolt in to my YJ. That's power steering for free!
ChevDog1 is offline   Reply With Quote
Old 09-22-2006, 08:29 PM   #5
Mr.B
Mr.B's Avatar
Well I went to J&W, the jeep junkyard today and they wanted $400 for a complete setup. Thats more expensive for used parts than from Kragen for rebuilt parts.
My Jeep
KB6NQT
Everyone is Welcome
Old 09-23-2006, 04:00 PM   #6
Mr.B
Mr.B's Avatar
Today I went to the pic a part, and found a 86 Cherokee Laredo with a 2.5L. The power steering looks like it will bolt on to my 2.5L. Here's a picture of the pump on the Laredo.
Here's a picture of my pulley where the pump should be mounted.
My Jeep
KB6NQT
Everyone is Welcome
Old 09-23-2006, 04:23 PM   #7
Mr.B
Mr.B's Avatar
Here is a better picture of my Wrangler. What I cant seem to get in a frame is that are three bolts holding down the idler pulley bracket. The center one, just below the belt, I believe is just for the pulley tensioner. The pump bracket on the Cherokee only seems to have two bolts.
My Jeep
KB6NQT
Everyone is Welcome
Old 09-29-2006, 10:03 PM   #8
Mr.B
Mr.B's Avatar
For those of you who are interested, I did pull the gearbox and pump from that '86 Cherokee 2.5L. The gearbox will bolt right into my Wrangler. The hoses won't work though. The return hose points straight up from the gearbox and interferes with the radiator bracket. And the pressure hose is too short. I haven't tried to mount the pump yet. I'll keep you posted on my progress. Unfortunately work keeps getting in the way.
My Jeep
KB6NQT
Everyone is Welcome
Old 09-30-2006, 12:05 PM   #9
jeeepguy
jeeepguy's Avatar
You'll be better off going to a place that makes the hoses and getting new ones rather than working with used ones. Better to not chance a dry, rotted, cracked hose for so little difference. Besides, you can then get any fitting you need to make it work.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
Old 10-07-2006, 10:15 AM   #10
Mr.B
Mr.B's Avatar
I agree. Buying them from the junkyard was a mistake. But I was only out about $16. I did get the sensor with it though. I don't know if my computer will read it, but it will at least plug the hole in the new pressure hose I bought from Napa.
My Jeep
KB6NQT
Everyone is Welcome
Old 10-07-2006, 04:23 PM   #11
southerndawg
That sensor was worth every bit of $16. I spent a good bit of time trying to find the right size bolt to plug it. Napa couldn't do it and neither could another shop. Ended up buying the sensor in the end.
-95 YJ 2.5
southerndawg is offline   Reply With Quote
Old 10-20-2006, 10:37 PM   #12
Mr.B
Mr.B's Avatar
I finally got it all together this week and it all worked. I had to buy a rebuilt pump from Napa, because the one off the XJ wouldn't fit. I got new hoses and used the sensor off the XJ to plug the hole. Your right, it was worth the $16.
My Jeep
KB6NQT
Everyone is Welcome
Old 11-07-2006, 10:46 PM   #13
Mr.B
Mr.B's Avatar
Just an update on the conversion.
After I got every thing in and started driving around, the gearbox started leaking around the stub shaft(where the steering column bolts on). I bought a seal kit from Napa for about $7. The 20 year old seals were a PIA to remove, but it's working great now.
My Jeep
KB6NQT
Everyone is Welcome
Old 11-08-2006, 09:23 AM   #14
southerndawg
Good job!
I had the same problem with a CJ gearbox I replaced. Had to replace a seal after we had it all mounted up. It was a pain to get to being so close to the radiator.
That 2.4 in your signature is a typo right?
Old 11-08-2006, 09:29 PM   #15
Mr.B
Mr.B's Avatar
LOL I've been on this forum almost a year now, and you are the first to notice that, including me. It's been fixed. Thanks.
My Jeep
KB6NQT
Everyone is Welcome
Glock Forum
