Power Steering Box Leaking - JeepForum.com
post #1 of 12 Old 04-07-2007, 02:16 PM Thread Starter
EJames1226
EJames1226's Avatar
Im leaking out of the adjusting bolt, on top of the power steering box. Any ideas?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #2 of 12 Old 04-08-2007, 01:58 AM Thread Starter
EJames1226
EJames1226's Avatar
Anybody ?
post #3 of 12 Old 04-08-2007, 02:08 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Just a seal going bad. Rebuild kits are available from AZ or Napa for about 20 bucks.
That's the adjustment bolt/allen, not sure if you need to take it all apart, think it simply unscrews, you might get lucky and be able to just pop a new o=ring on there.
- Ernie
Richmond88yj is offline
post #4 of 12 Old 04-08-2007, 02:29 AM Thread Starter
EJames1226
EJames1226's Avatar
INtresting... a rebuild kit eh? That would be fun. For 20 bucks i might as well just rebuild it, for the fun of it. Is it hard to do?
You sure are posting alot tonight...
post #5 of 12 Old 04-08-2007, 02:39 AM
Richmond88yj
Eat, Sleep, Jeep
Heh, catching up Can't sleep.
Yeah the gear is held on by 4 bolts, pretty easy to remove, but if you're just doing that one seal you can do it without removing the steering gear. If you simply want a new one, go to the JY or dealer and get one for a Dakota pickup, exact same part, but 50% cheaper than asking for one for a YJ.
- Ernie
post #6 of 12 Old 04-08-2007, 02:41 AM Thread Starter
EJames1226
EJames1226's Avatar
I think i wanna rebuild it, just to learn about it... that could turn into a expensive project though knowing me.
post #7 of 12 Old 05-03-2007, 05:11 PM Thread Starter
EJames1226
EJames1226's Avatar
Okay time for stupid questions.
Rebuild kits are 40 bucks.
If i just want the O-ring, i need to take out the old o ring and bring it in. How do i get to it the easiest way?
post #8 of 12 Old 05-03-2007, 06:38 PM Thread Starter
EJames1226
EJames1226's Avatar
Oh yeah, autozone thinks im lieing when i say that the power steering box is diffrent than the pump. Am i wrong when i say that or am i right? Always thought they were diffrent.
Im taking the bolts off the steering box right now (the 4 in the picture) in hopes of finding the o-ring.
post #9 of 12 Old 05-03-2007, 06:40 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
The rebuild kits are just a bunch of seals and O-rings, I believe. I'll bet if you try to get that seal out, all you'll get is chunks. And you will probably change the adjustment of your steering, unless you can figure out how to put it back to the exact turns before you started.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #10 of 12 Old 05-03-2007, 06:58 PM Thread Starter
EJames1226
EJames1226's Avatar
I just got the cap off of the power steering box, sorta. The power steering fluid is draining out right now. Ill take pics of what i have shortly.
post #11 of 12 Old 05-03-2007, 07:40 PM Thread Starter
EJames1226
EJames1226's Avatar
Just put it all back together, steering is normal now, not tight like it was before, and its not gushing out fluid anymore...
post #12 of 12 Old 05-04-2007, 05:13 AM
drew2000
drew2000's Avatar
Uhhhhhhhh yeah. Two different parts.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
TJ power steering box leaking sporticon03 TJ Wrangler Technical Forum 9 08-12-2009 08:32 AM
Power Steering Leaking cptjaredkent TJ Wrangler Technical Forum 2 03-28-2009 12:48 PM
Power Steering Leaking samron333 TJ Wrangler Technical Forum 10 02-25-2009 04:27 PM
power steering was leaking...now is not. ktaylor448 TJ Wrangler Technical Forum 0 09-20-2008 09:02 AM
power steering box leaking fuzzbal981 TJ Wrangler Technical Forum 4 03-18-2006 12:55 PM
