Is power stearing fluid and ATF the same in a jeep power stearing unit? - JeepForum.com
post #1 of 11 Old 09-11-2011, 12:06 PM Thread Starter
ciclone429
1987 YJ Wrangler
Older fords use ATF for power stearing. Is it the same in a jeep?
ciclone429 is offline
post #2 of 11 Old 09-11-2011, 12:08 PM
thirdeye
No
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #3 of 11 Old 09-11-2011, 12:39 PM
sbsg2005
been running atf in my ps pump for 3 yrs in my jeep and 8 in my truck with no issues just cause its cheaper.
sbsg2005 is offline
post #4 of 11 Old 09-11-2011, 08:11 PM
burnout189
no its not the same.
they used to run atf in the power steering back in the old days, but i wouldnt recommend it.
is it really worth saving 3 dollars to risk burning up your p/s pump?
BARNHART'S AUTO REPAIR
burnout189 is offline
post #5 of 11 Old 09-11-2011, 08:49 PM
autoboy454
All the new Chryslers use ATF+4 instead of P.S. fluid... Just saying...
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #6 of 11 Old 09-11-2011, 09:05 PM
SpikesHD
1987 YJ Wrangler
I've always used ATF in everything instead of PS fluid. 5 trucks, nice car, Jeep, tractors, 2 motorhomes, the only PS pump failure I've had in on an '87 Chevy 350TBI because the bearing failed on the front of the pump. The belt tensioner locked up.
YMMV
Si vis pacem, para bellum.
SpikesHD is offline
post #7 of 11 Old 09-11-2011, 10:31 PM
Castr8r
I feel that using ATF instead of PS fluid was a big factor in my PS pump self-destructing. I would use what the factory recommends; there's a reason for it. Just sayin'...
I've been throwed out of a carwash- too much mud!
I've done bodywork useing a winch, a tree, a prybar, and a BFH!
Now, my wild oats have turned to prune juice and all-bran...
Castr8r is offline
post #8 of 11 Old 09-11-2011, 10:39 PM
bigbossd1030
Atf use in a ps unit is to get you to a shop or a mech in an emergency. It is NOT the same. It isn't the same consistancy as ps fluid and in the long run is a bad idea, use it in an emergency if you get a leak, it will buy you some time to get it fixed.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #9 of 11 Old 09-11-2011, 10:55 PM
4.7stroker
I have been using it for years withou issue.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #10 of 11 Old 09-12-2011, 10:36 AM
burnout189
who really knows :/
its one of those arguements that will never cease.
the general concensus is,
you SHOULD be fine running ATF,
you WILL be fine running P/S fluid.
take it as you wish.
post #11 of 11 Old 09-12-2011, 12:14 PM
bigbossd1030
Well said
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
Power stearing and gas pedal malfunction... joe-mama JK Wrangler Technical Forum 5 09-08-2011 01:57 PM
Man Stearing YJ w/4.0L H.O. and stearing assist JohnFM3 YJ Wrangler Technical Forum 2 10-19-2009 10:34 PM
power stearing problem BadAssTJdriver TJ Wrangler Technical Forum 1 05-19-2005 08:14 PM
Power Stearing WR4NGLER TJ Wrangler Technical Forum 0 09-06-2004 11:11 AM
Power Stearing? Naum42 YJ Wrangler Technical Forum 0 05-21-2001 04:56 AM
