Power Master alternator install help - JeepForum.com
post #1 of 19 Old 12-17-2012, 07:15 PM Thread Starter
89YJBuilder
The last time I had the Jeep out it puked up the old alternator and Optima Red Top. So I exchanged the battery for a new one and finally bought a 140amp Power Master alternator to replace the old one. I started to install it today and after mounting it I started to remove the "charge" wire from the harness to replace it with the included heavier one. Well the new cable has a ring terminal on both ends and when I got to the end of the factory wire it came to a "fuse-able link" and a Y. After the Y it goes to a block on the fire wall that has two post connectors. It is just below the battery tray and to the right of the engine; the battery side. I am not sure if it is a distribution block or an external regulator? Tthe regulator is internal on the GM IS12 style alternator, right? I am working on an '89 YJ with a 2.5l. I am a little confused at the time. I believe that I could just cut the wire at the Y, effectively removing the fuse-able link, and bear a spot on the new wire and solder them together correct? Then use the ring terminal on the replacement wire to connect to the block. This "block" on the firewall has thrown me a bit. Anybody know what it is? I could realy use a hand.
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
post #2 of 19 Old 12-18-2012, 11:15 AM Thread Starter
89YJBuilder
Bump
KG6YSF
post #3 of 19 Old 12-18-2012, 01:10 PM
trboxman
1987 YJ Wrangler
I have a Power Master 140 amp alternator on my '87 4.2, it's not an external voltage regulator. It may be your starter solenoid/relay.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #4 of 19 Old 12-18-2012, 01:34 PM
Siva283
Message Que89yj. He is the tech forums electrical guru/god. He will explain to you all of your question and explain how to mod this the right way.
Ask me how I know...
Siva283 is offline
post #5 of 19 Old 12-18-2012, 02:55 PM
pete1991YJ
This X2.... where has Que been lately?
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #6 of 19 Old 12-18-2012, 02:56 PM
Siva283
I have been wondering that myself. Hopefully he is on a vacation having fun
Sent from my PC36100 using JeepForum
Siva283 is offline
post #7 of 19 Old 12-18-2012, 07:02 PM Thread Starter
89YJBuilder
OKay. I know that the starter solenoid is mounted to the starter housing so I'll bet it is the relay. I never figured that the charging wire would go to the starter relay? I'll do some more research and try to contact Que89yj.
Thanks all.
KG6YSF
post #8 of 19 Old 12-18-2012, 07:13 PM
wncYJ
wncYJ is offline
post #9 of 19 Old 12-18-2012, 07:24 PM Thread Starter
89YJBuilder
That would be outstanding! Thank you very much.
kg6ysf@yahoo.com
KG6YSF
post #10 of 19 Old 12-18-2012, 07:40 PM
wncYJ
wncYJ is offline
post #11 of 19 Old 12-20-2012, 11:46 PM Thread Starter
89YJBuilder
Thanks all for the input. I tried to contact Que89yj. But so far I have not heard from him/her.
KG6YSF
post #12 of 19 Old 12-28-2012, 12:06 AM Thread Starter
89YJBuilder
Well I cut the factory charge wire at the Y. I left the remaining wire connected and then ran the new charge wire to the same connector post that the factory wire runs to. I also ran a #10 wire from the alternator mounting bolt to the engine block, and one from the same bolt to the frame.
If anybody can see a problem with this please let me know. Thanks.
KG6YSF
post #13 of 19 Old 12-28-2012, 08:18 AM
NHfireLJ
NHfireLJ's Avatar
For a hi amp install...
Run the new Powerlead from the alt to the battery (should be 4 awg or larger) with a 150 amp fuse or circuit breaker.
Run new grounds 4 awg also. 1. alt to block, 2. battery to block and 3. block to chassis (10 g is a bit small)
Feed to PDC directly from the battery
feed starter directly from the battery
NO SOLDERING mid point as mentioned. use ring terminals on ends to have solid connections..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #14 of 19 Old 12-28-2012, 02:22 PM Thread Starter
89YJBuilder
According to Power Master tech support, all that is needed is to run the supplied wire to the battery and add a ground from the alternator mounting bolt to he frame or engine block. #10 is well suitable. Thanks to all who have added input.
Looks like I will be undoing some of what I did. I wish I would have waited to talk to them before doing anything. Not the first time I have had to undo something that I did do to lack of patience. Oh well live & learn.
KG6YSF
post #15 of 19 Old 12-28-2012, 05:42 PM
NHfireLJ
NHfireLJ's Avatar
Just remember that its your jeep and not powermasters... All other Hi Amp Alt upgrades have includes the big 3...
•Upgrade the charge lead from the alternator output stud to the battery
•Upgrade the return path between the alternator and vehicle ground
•Upgrade the return path between the battery negative (-) and the vehicle ground
and most recommend matching gauge wire for grounds... Might as do it right the first time and not worry down the road...
Just food for thought. Good luck
SOLD
YJOTM FEB 2013
NHfireLJ is offline
