Power loss in reverse! - JeepForum.com
post #1 of 9 Old 07-04-2011, 10:06 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So when on flat ground my jeep drives in reverse just fine but when backing up a hill my jeep just chokes up and want to die! I don't know if it is related at all but my cel is on with a code 24/25 and I have the new iac and tps ordered! Any ideas on what could cause this?
zte87 is offline
post #2 of 9 Old 07-04-2011, 05:08 PM
bharris68
Daily Driver
Search for those codes here on J/F and you should get your culprit. One of those two I think is A/C (Which I don't think many of us have), and the other may be your suspect.
bharris68 is offline
post #3 of 9 Old 07-04-2011, 05:13 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
the codes are for the iac and tps sensors this is driveing me nuts!
zte87 is offline
post #4 of 9 Old 07-04-2011, 05:57 PM
Noltz
YJ Wrangler
well a TPS not functioning right will certainly cause a sputter or low power.
Does it work fine forward up a hill? I'm thinking perhaps the engine torquing is causing something to short out. Had a Toyota that the Crank Sensor wire was shorting against the power steering line, but only in reverse when you backed up fast (or up a hill). It would stall, but immediately restart.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #5 of 9 Old 07-04-2011, 06:56 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Yeah it drive up hill forward just fine! I did order new iac and tps sensor's and should have it this week!
zte87 is offline
post #6 of 9 Old 07-04-2011, 07:48 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I don't think either sensor is bad. The odds of bith of them being NG is too remote. Code 25 does mention a vacuum leak as a possible cause. I would check for a vacuum leak especially at the MAP sensor. That sensor sends a message back to the brain which uses that signal to regulate fuel flow.
Or, you got a wire rubbing up against sumtn!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #7 of 9 Old 07-04-2011, 08:41 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
it could be a vacuum leak being that I have a nasty exhaust leak somewhere on the manifold! I figured at least one of the sensor is bad tow because when I first start the jeep after its been sitting awhile I have to stay on the gas until its warmed up a little or it will die! I am going to be replacing the manifold (I think it is cracked) with more than likely a cheap pacesetter when I do this I will try and make sure I don't have vacuum leak at that time!
zte87 is offline
post #8 of 9 Old 07-04-2011, 08:53 PM
dodger889
exhuast leaks only mess up the O2 sensor not the others. I would check over the vacuum lines make sure none of them are getting bad.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #9 of 9 Old 04-17-2013, 08:25 AM
mauricioarce
Did you get a solution
Hello there
Did you get a solution for this issue
I have the exact same problem my Jeep is a 199 TJ with 2.5 engine
Please let me know
mauricioarce is offline
