power to the coil question - JeepForum.com
post #1 of 3 Old 06-02-2010, 04:32 PM Thread Starter
wvcracker
I searched with no results I Bought a 88 YJ with a 4.2 it cranks but wont start so i check for spark NONE so i check power at the coil i am getting a posative reading at both the negative and pos. hook ups is this correct? if not what should i look at next? please help cant seen to figure it out.
wvcracker is offline
post #2 of 3 Old 06-02-2010, 05:40 PM
vector6
ignition module
vector6 is offline
post #3 of 3 Old 06-02-2010, 07:34 PM Thread Starter
wvcracker
thats what i thought just wanted a second guess thank you for the reply.
power to the coil but no spark from the distributor 97tjeff YJ Wrangler Technical Forum 9 04-27-2011 04:15 PM
95 YJ 4.0 No power to the coil crashdnt YJ Wrangler Technical Forum 7 03-14-2011 10:39 AM
Power going to coil Mikerp97 YJ Wrangler Technical Forum 6 12-02-2009 09:09 AM
Broke down - Ignition Coil not getting power Unscathed YJ Wrangler Technical Forum 34 04-16-2008 09:19 AM
power to the coil raysnutt18 TJ Wrangler Technical Forum 3 12-03-2007 04:18 PM
