Powder coating intake and exhaust manifolds - JeepForum.com
post #1 of 16 Old 04-28-2013, 12:28 AM Thread Starter
bck4more
1987 YJ Wrangler
So motor is in shop and i wanna make the engine look all good for alittle atleast so im thinking of dropping the intake and exhaust manifolds off to get powder coated. I know the exhaust needs to be ceramic coated but what about the intake can i just have it powder coated or does it get to hot for that? Thanks
bck4more is offline
post #2 of 16 Old 04-28-2013, 07:21 AM
jay-h
Probably too hot unless someone is offering a specially made coating.
There are shops that specialize in this sort of thing for hot rodders, if it means that much to you, check them out.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #3 of 16 Old 04-28-2013, 07:39 AM
Plato2k5
You can use normal powder on the intake.
I did this in the garage.
200k miles later its still there. Its a black wrinkle finish
Plato2k5 is offline
post #4 of 16 Old 04-28-2013, 07:56 AM
Dirttracker18
If your intake get too hot for powder coating you have bigger problems
The exhaust on the other hand will not stand up to powder, as you noted.
If you are going that far, a header is a better upgrade and can be purchased pre coated, make more power and improve MPG a little.
Dirttracker18 is offline
post #5 of 16 Old 04-28-2013, 10:08 AM
davsyjdd
The standard powdercoat will hold up to about 400 degrees. I have done many intakes,Valve covers,oil pans ect. and had no problems. Exaust, I have had them stay nice (with high temp exaust/BBQ) for awhile but not permanent.
davsyjdd is offline
post #6 of 16 Old 04-29-2013, 09:51 AM
vadslram
If you do the intake with a dark color you will be fine. Anything bright or white will start to discolor around the points close to the exhaust. Radiant heat from the exhaust will exceed 600 F.
vadslram is offline
post #7 of 16 Old 04-29-2013, 11:00 AM
jserna
1987 YJ Wrangler
Find a shop that will ceramic coat your exhaust manifold. It might be cheaper to buy a header that is already ceramic coated.
jserna is offline
post #8 of 16 Old 04-29-2013, 03:16 PM Thread Starter
bck4more
1987 YJ Wrangler
I just dropped both my intakes off to get ceramic coated with lots of other parts being powdercoated
bck4more is offline
post #9 of 16 Old 04-29-2013, 08:26 PM
plym49
Jet-Hot for the exhaust manifold. Silver or black.
If your ceramic-coated exhaust manifold gets wet when it is hot the coating will crack and rust will form underneath.
plym49 is offline
post #10 of 16 Old 04-30-2013, 08:12 AM Thread Starter
bck4more
1987 YJ Wrangler
Really? I never heard that before.[
QUOTE=plym49;15365889]Jet-Hot for the exhaust manifold. Silver or black.
If your ceramic-coated exhaust manifold gets wet when it is hot the coating will crack and rust will form underneath.[/QUOTE]
bck4more is offline
post #11 of 16 Old 04-30-2013, 08:25 AM
EABiker
Geez, I love the way that looks; I wish my Jeep was worthy of something like that!
EABiker is offline
post #12 of 16 Old 04-30-2013, 08:51 PM
plym49
[/QUOTE]
Yup. Check out the exhaust manifolds on any stock 6 cylinder E-Type Jag that is street driven. Ceramic coated right underneath hood louvers.
plym49 is offline
post #13 of 16 Old 04-30-2013, 10:46 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #14 of 16 Old 05-01-2013, 12:06 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by DirtKar View Post
Anything to add? I deem you the resident expert on the matter.
Anticanman is offline
post #15 of 16 Old 05-01-2013, 09:32 AM
DirtKar
DirtKar's Avatar
Well, everyone loves a good deeming.
Here's my take on this- The engine is already out and at the shop. There is no issue with powdering the intake, it will hold up just fine. You can even do it yourself, it's very easy. I can give some tips and lead you to some applicable reading if you like. Keep in mind that powder shops don't care for doing onsies and twosies. There's no money in it for them. The more parts you bring the better the price you will get because it's not cheap to fire an oven... They may even hold your part for a day or two so that they can cure a larger batch at once, of course this depends on how busy the shop is. The OP and others that have offered opinions are correct in their summation that the exhaust needs to be of a more durable coating like a ceramic. I'm not sure that I would bother with paying to have the stock crack prone exhaust manifold ceramic coated. You may be better off paying just a bit more for a decent header that will provide additional HP gains as well. Win Win, right? The engine is out, nows the time to do the things you will regret not having done later. Good luck with your build.
YJOTM JULY 2014
DirtKar is offline
