Post Nutter Questions - JeepForum.com
post #1 of 5 Old 08-30-2014, 02:14 AM Thread Starter
dennisonwj
I have finished the nutter bypass on my 88 YJ. Unplugged and remove the ECU afterwards, started the Jeep. Never ran better than it does now, amazing. I went ahead and removed the damn computer altogether and traced and removed all wires that were connected to it. I still have to splice together any bundles that I had to cut to get the computer wire out of the mix. Then start it again to see if all is working.
Should I leave the O2 sensors in the exhaust manifold and the top of the tail pipe fitting in or remove them and plug the holes. The computer was wired to them therefore I am assuming with a truly mechanical set up they do nothing.
dennisonwj is offline
post #2 of 5 Old 08-30-2014, 06:38 AM
bpounds
bpounds's Avatar
Leave it or plug it, doesn't matter. It isn't connected to anything so it won't matter.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #3 of 5 Old 08-30-2014, 07:28 AM
Old4X
1990 CJ7
The O2 sensor can still be used with a meter to read A/F ratio on your carb. Even if you don't use it, it hurts nothing just to leave the sensor in the bung.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 5 Old 08-30-2014, 08:46 AM
Mike Romain
Some folks leave them to help with setting the mix. They look for .45- .6v on a meter if I remember right. Range is .1-.9 I think.
Some folks also wire the solvac to a fused powered switch so they have a manual fast idle for things like winching or boosting.
Mike
Mike Romain is offline
post #5 of 5 Old 08-30-2014, 01:56 PM
dancytron
I have the solvac wired to a toggle switch. It's really handy for when it is very cold (below 10 degrees F) to keep the idle high until it is warmed up.
dancytron is offline
