Post-modification oops. - JeepForum.com
post #1 of 18 Old 09-16-2011, 03:32 PM Thread Starter
4x4_Medic
Ok, I had my killswitch thread in here, but since this is now something new, I think it needs a new thread. I tried wiring a killswitch in onto my fuel pump relay. It worked for a moment, then when I tested to make sure the car wouldn't start afterwards, it died and I havn't been able to bring it back to life since. I have removed the switch for now, and spliced the wires on the relay back together.
My engine cranks, the fuel pump is working, because I know I have fuel pressure, and it was working fine just before I put the switch in. Does anyone have the slightest idea of what it could be, so I don't have to drag this thing over to a shop?
4x4_Medic is offline
post #2 of 18 Old 09-16-2011, 03:34 PM
superj
did you burn up a ground or something?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 18 Old 09-16-2011, 05:10 PM Thread Starter
4x4_Medic
Honestly, I have no idea. I only know just enough about electrical systems to put the switch in. I have no idea what I should be looking for. One of the reasons I'm asking here. Which grounds might I have damaged, and where would I find them? Things like this are what's really throwing me off. I checked the fuses and they were all good. Checking my fuel lines, I know I'm still getting fuel flow, so the pump is working. I just can't figure out what's keeping this thing from kicking over, now.
post #4 of 18 Old 09-16-2011, 05:32 PM
fratis
fratis's Avatar
how do you know you are getting fuel?
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 18 Old 09-16-2011, 05:37 PM Thread Starter
4x4_Medic
The fuel rod on my engine has a little test port on it. If I touch the port with a screwdriver, I get a little flood of fuel. I try cranking again, and tap the fuel test port again and I get the same little flood of fuel.
post #6 of 18 Old 09-16-2011, 06:03 PM
shadowulf
Check for a loose ground. I had something similar happen when I installed my tilt steering wheel. In short, no ground = no fuel injection. And when you find it, hook you switch inline with it. Its a killswitch dream, no fuse and hard to bypass unless you are looking for it.
" All jeeps are destined to be the parts pile for the next project" :Unknown
shadowulf is offline
post #7 of 18 Old 09-16-2011, 06:07 PM Thread Starter
4x4_Medic
Well, where would I find these grounds? Because the one thing I touched was the power distribution box under the hood, which I've done before when trying to find the right wire before I did this, and had nothing bad happen, and the white/yellow wire coming to the fuel pump relay, which is now re-connected. Other than those two areas, I have touched nothing.
post #8 of 18 Old 09-16-2011, 07:55 PM
sbsg2005
Have you checked to see if you have spark, you know you have fuel pressure but can you tell if the injectors are firing?
sbsg2005 is offline
post #9 of 18 Old 09-16-2011, 08:25 PM Thread Starter
4x4_Medic
No, I can't tell if I have spark. I don't have a spark plug socket.
post #10 of 18 Old 09-16-2011, 09:41 PM
Mark05059
take a plug wire off... stick a screwdriver in the end of it... position the screw driver so that its close to something metal but not touching... then turn the engine over while watching for sparks to jump.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 18 Old 09-16-2011, 10:29 PM Thread Starter
4x4_Medic
Ohhhhhh.....ok. Just got to wait until someone else is around, then.
post #12 of 18 Old 09-16-2011, 10:58 PM
MoparFreak69
When you push the little valve (schrater valve) in on the fuel rail it should shoot out with a bunch of pressure, not just sorta flow out. The pressure in the system when the pump is functioning properly is about 40PSI. There should be enough pressure in there so that when you push the schrater valve in it will probably spray into your eyes (happened to me the first time I did it without wearing safety glasses) and all over you in the process. If you arent getting a high pressure blast then your pump isnt functioning properly. It could have simply lost its prime, which should build back up with cycling the key a couple of times.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #13 of 18 Old 09-16-2011, 11:26 PM
fratis
fratis's Avatar
figured but thought id ask.
mine never does this. it kinda dribbles out. has always run fine. weird.
fratis is offline
post #14 of 18 Old 09-17-2011, 12:52 PM
MoparFreak69
Your Jeep either has TBI or a carburetor (if you have the original engine in it), the pressures in the fuel line are lower than 92+ MPI engines. The carb functions between 3 and 8 PSI while the TBI system works at somewhere around 20 PSI. A dribble is normal for these earlier systems, not for later higher pressure systems.
post #15 of 18 Old 09-17-2011, 01:00 PM
fratis
fratis's Avatar
no its a 91, mpi.
fratis is offline
d30 = oops 96jeepin TJ Wrangler Technical Forum 16 08-24-2011 08:34 PM
OOPS! Is this bad . . . . YJ Newby YJ Wrangler Technical Forum 21 11-29-2006 09:54 PM
oops scoutout TJ Wrangler Technical Forum 6 11-02-2006 07:43 PM
Oil pan Oops! rmagers TJ Wrangler Technical Forum 10 06-26-2005 08:48 PM
