Possibly a bad starter? - JeepForum.com
post #1 of 18 Old 02-12-2014, 10:08 AM Thread Starter
Klipsch20
I drive a yj with only 90k miles on it, a couple months ago, once it first dipped below about 35 degrees or so, my jeep wouldn't start, it clicks once and only once when the key is cranked. the voltage gauge reads at about 8 so i know its not a battery problem, but i cleaned the terminals and connectors anyways, i took it to autozone to check the starter but got distracted by bad connections to the battery and cleaned those instead. to get it started i have to turn the key several times, wait a few minutes, then try cranking it again, and when it does finally crank over its super slow and takes between 4-8 seconds to finally turn over and start. so my first guess is the starter, what do you guys think?
Klipsch20 is offline
post #2 of 18 Old 02-12-2014, 11:15 AM
Jeepsr4me
Check your battery. 8 is not the correct voltage. More like 12-13
Jeepsr4me is offline
post #3 of 18 Old 02-12-2014, 11:31 AM
Mark05059
at rest the battery should read no less then 11 volts. Get your battery tested.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 18 Old 02-12-2014, 12:49 PM
dancytron
Did you also clean the ground to the engine block?
Battery cables will corrode on the inside and look fine, but be trashed. Consider replacing them.
If you are very careful, you can use a set of jumper cables to bypass the old battery cables as a test.
dancytron is offline
post #5 of 18 Old 02-12-2014, 08:12 PM
jbeebe
On cold mornings i'm not surprised your voltage is reading that low. Sometimes mine is as well after sitting for a couple days in the cold, but it should still crank, albeit slowly, at 8V.
Next time it happens try having someone hit the starter with a hammer over and ovoer while you're trying to start it. If it all of a sudden starts, you know it's the starter. Or just replace the starter and see if it works! Whenever my vehicles "click" and don't crank, the starter is usually the first place I go if i know the battery isn't dead.
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #6 of 18 Old 02-12-2014, 10:41 PM
bpounds
bpounds's Avatar
Oh come on. He said it was 35 degrees. Not even freezing! There is no way it should be cranking slow, and 8 volts is a dead battery. Not just weak, but dead. I don't know if the PO can actually properly read a voltmeter, but if the battery is really 8 volts, it is bad. Probably a shorted cell.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #7 of 18 Old 02-12-2014, 10:42 PM
Why J?
Why J?'s Avatar
Get a new battery.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #8 of 18 Old 02-12-2014, 10:55 PM
RedRockRed
2010 JK Wrangler
Battery.
RedRockRed is offline
post #9 of 18 Old 02-13-2014, 04:23 PM
Rproject
1987 YJ Wrangler
Oh come on bpounds, a little harsh today, aren't we? Dang dude!
OP, if it's your starter, she'll crank and crank and crank and not turn over. Get your battery tested like the others have said. If your battery comes back as good, it could be something as simple as the wiring harness at the bulkhead (where it passes through the firewall) has corrosion on it. Or your battery cables could be internally trashed as stated above.
I'm with the group on this one ---- leaning towards the battery, not the starter.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #10 of 18 Old 02-13-2014, 05:00 PM
bpounds
bpounds's Avatar
Yeah, maybe a little harsh. Thing is, I wasn't going to join in on this thread, because the question was pretty basic, and should have been an easy answer. But when replies suggested barely cranking over in above freezing temps was normal, I guess I vented a little.
And I still don't get this:
Originally Posted by Klipsch20 View Post
...the voltage gauge reads at about 8 so i know its not a battery problem,...
Does anyone really think 8 volts is okay?
Bill
bpounds is offline
post #11 of 18 Old 02-13-2014, 05:16 PM
Rproject
1987 YJ Wrangler
I hear ya on the 8 volts gig. You need at least 10 to get anything going. 8 just ain't gonna cut it.
1996 White ZJ
Rproject is offline
post #12 of 18 Old 02-13-2014, 05:47 PM
jay-h
Originally Posted by jbeebe View Post
... Whenever my vehicles "click" and don't crank, the starter is usually the first place I go if i know the battery isn't dead.
Click but no crank is very often battery cable connections. Do a voltage drop test on both hot and ground side
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #13 of 18 Old 02-14-2014, 11:00 PM
hanshunter
Starter solenoid...exactly the same thing happened on mine.
hanshunter is offline
post #14 of 18 Old 02-15-2014, 08:02 AM
Rproject
1987 YJ Wrangler
It is a possibility, and if that is what it is, on the later YJ's, it'll need a new starter. Early ones had the solenoid on the firewall.
1996 White ZJ
Rproject is offline
post #15 of 18 Old 02-15-2014, 09:47 AM
bpounds
bpounds's Avatar
How does that explain 8 VDC?
Of course, the OP could be reading that off his dash gauge, which is worthless. He has another thread going on this same issue, and he has other electrical gremlins too.
Bill
bpounds is offline
ignition , starter , starter issue , starting issue , starting problems
