-   -   possible tail light mod? (http://www.jeepforum.com/forum/f12/possible-tail-light-mod-1769634/)
NHYJ4213 11-07-2013 08:04 PM
So the rather large rectangle tail lights make gas can fill ups a pain but I noticed JKs have a thinner version... would it be possible to wire them up instead of the stock yj ones? I know there's the filler relocation mod and the round led mod but think this would be cheaper and probably a lot easier. .. besides I'm not a huge fan of round lights :p
irnmadn88 11-07-2013 08:15 PM
The JK body contour is much different than the YJ.
IIRC- the trick to using a gas can with a YJ was to thread the neck so that it stuck out of the body of the can sideways...
Anticanman 11-07-2013 08:26 PM
Flush mount the stock lights. JeeperDon did it. He's a bit of a Scrooge but an endless source of information.
NHYJ4213 11-07-2013 08:27 PM
I was hoping it'd work lol. Ill end up doing filler relocation at some point anyways
NHYJ4213 11-07-2013 08:28 PM
By cutting into tub and sinking them in?
Anticanman 11-07-2013 08:38 PM
Yeah. It costs work.
NHYJ4213 11-07-2013 08:42 PM
Sounds expensive! :rofl:
Day215 11-07-2013 10:37 PM
Mine are flush, it's still a pita to fill up, it's a jeep thing?!
http://i918.photobucket.com/albums/a...918F7B8745.jpg
SunDevilJeeper 11-08-2013 03:12 AM
50 Attachment(s)
:laugh:
I'll agree with that one, he does know what he's talking about though.
debord97 11-08-2013 03:47 AM
Day215 did you do a right up on flush mounting those tail lights? I have been wanting to do this for awhile instead of changing to round LEDs.
jsawduste 11-08-2013 05:16 AM
jsawduste is a bit of a Scrooge but a source of information.
Fixed it for you Nick ! :teehee: :wave:
Anticanman 11-08-2013 07:25 AM
Tooting your own horn, John? :D
Day215 11-08-2013 07:46 AM
EDIT******this guy was way more motivated than I was, he took pics along the way. I did make sure to cut my template with a lot more precision. I wanted to see exactly where the light was going to sit when done, not just the portion I needed to cut out.
http://www.jeepforum.com/forum/f9/ho...-pics-1014417/
I didn't post a write up, but here's a quick overview.
#1: remove tailights
#2: make a template from cardboard, I placed the light lens down and cut out the outer shape on cardboard, I then carefully cut out the inner portion of the template to match the contour of the backside of the light. The backside of the housing is tapered, I just kept trimming until the template would snugly slide over the backside of the housing. You basically end up with a cardboard "ring" that looks like the shape of the light.
#3:mask off the area you think the light will occupy, I slid the backside of the housing just a hair under the rear wheel well.
#4: square up your template and trace the inner portion. Cut the inner portion out, I used a jigsaw but a dremel would work a bit better.
#5: stick the light in the hole and check the fit, trim as needed. Once your happy, mark the four holes that hold the lens to the housing, these holes will be the fastening points for the light to the body. A sheet metal screw will go thru the lens then housing then body.
#6: run a small piece of wire from a ground point on the chassis to the screw inside the lens on the chrome reflector part of the lens. The old way of mounting the light provided a ground for the housing, when you remove the metal that it mounted to, you need to find an alternate way to ground the housing to the chassis.
#7: I ran some clear silicone around the housing lip before i placed the light into its new hole and screwed it in. Smooth the silicone out with your fingertip to seal the housing to the body. Plug it in and test her out
My explanation makes no sense to me, your basically just cutting a hole and sinking the light into the larger hole, don't over think it! You will loose your side marker, these are required by law in most if not all states, don't call me if you get a ticket. You will also need to address the deletion of your plate light, I bought some by lights and installed them just above the plate, I painted the old clear part of the lens that acted as the plate light so it would not bleed light into the wheel well.
debord97 11-08-2013 09:25 AM
Thanks for the reply Day215. Yea I will figure something out as far as the side markers go and the license plate light won't be a problem. Only thing I am worried about here is room for the counter sunk light housing. I have done the fuel filler relocation and there might not be enough room for both. Something I will have to check into.
Peety 11-08-2013 12:01 PM
1 Attachment(s)
I used square surface mount truck LED's from my local trucker store. For side markers I used 1" round red LED's. License plate was a tripple white LED, I cut a slot in the housing and flush mounted it. The plate clears it by about 1/4".
The whole project cost about $130.00
The time now is 02:13 AM.
