Possible Oil Pressure Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Possible Oil Pressure Problem
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 08-15-2008, 04:24 PM   #1
jcook1989
My oil pressure gauge used to just sit at 40 but recently it has started to fluctuate. It goes a little under 40 at idle and goes up to about 60 when under load. Not sure if this normal or could be the indication of a problem. Does anyone have insight into this? Thanks.
jcook1989 is offline   Reply With Quote
Unread 08-15-2008, 04:59 PM   #2
laybackman
laybackman's Avatar
Fluctuating oil pressure is normal. As an engine get some miles on it the oil pressure values will drift apart more & your highest oil pressure reading will also fall off some. Idle oil pressure will be farther apart than 55MPH driving oil pressure. Another thing to consider is the weight of oil you run in your motor.
My '01 GC used to have ~ 60lbs+ oil pressure at hot idle when I bought it new. Oil was changed by me personally every 3k miles yet my high oil pressure reading is now ~55lbs at hot idle 70k miles later.
laybackman is offline   Reply With Quote
Unread 08-15-2008, 05:02 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Sounds absolutely normal to me.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Unread 08-15-2008, 05:42 PM   #4
zekthecat
x2 of above. Sounds normal. I would be more worried about low oil pressure then anything else.
zekthecat is offline   Reply With Quote
