Possible heater core leak ? - JeepForum.com
post #1 of 17 Old 06-10-2013, 05:37 PM Thread Starter
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
This morning on my way to work (6 mile commute ). I was sitting at a red light and notice steam coming from my defroster vent and it had the sweet coolant smell. So I looked on the ps floor pan to find a small puddle. I thought my heater core had took a crap on me. Once I arrived at work I had topped off the coolant. On my way home from work it did not emit any steam or leak any coolant does anyone have any Idea what the issue could be before I rip out the heater box and replace everything ?
Btw it's on the 89 with 4.2l. The temp gauge reads 195. The entire time
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #2 of 17 Old 06-10-2013, 05:49 PM
Reno72
Sounds like the heater core to me....sorry
Reno72 is offline
post #3 of 17 Old 06-10-2013, 05:51 PM
bigbossd1030
Originally Posted by Tom95YJ
This morning on my way to work (6 mile commute ). I was sitting at a red light and notice steam coming from my defroster vent and it had the sweet coolant smell. So I looked on the ps floor pan to find a small puddle. I thought my heater core had took a crap on me. Once I arrived at work I had topped off the coolant. On my way one from work it did not emit any steam or leak any coolant does anyone have any Idea what the issue could be before I rip out the heater box and replace everything ?
Have you ever replaced the heater core before? Check the hoses on the firewall under the hood and make sure they are connected nice and tight. It's possible that a piece of debris has clogged the hole. It's not a hard job to take out the heater core. The bolts for the blower housing are all on the firewall side and are easy to reach. Steam is a good sign of a heater core taking a crap all over the place.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 17 Old 06-10-2013, 05:53 PM Thread Starter
Tom95YJ
Tom95YJ's Avatar
The hoses are good on the underhood side I have replaced a heater core before but it was a task (94 z28)
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 17 Old 06-10-2013, 06:13 PM
bigbossd1030
Ok I would bet this is the heater core and this one will be a cake walk. The hardest part was making sure the defroster vent lined up right and all the cables.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #6 of 17 Old 06-13-2013, 08:40 AM Thread Starter
Tom95YJ
Tom95YJ's Avatar
Well I am 100% positive it's the heater core. I didn't leak for a few days. But it did leak some more today. I noticed that it leaks when I take the rpm upto 3000 it will start to leak when I shift at 2200 it will not leak.
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 17 Old 06-13-2013, 08:53 AM
Old4X
1990 CJ7
Just bypass it under the hood, fix it when it starts getting cold again.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 17 Old 06-13-2013, 09:20 AM Thread Starter
Tom95YJ
Tom95YJ's Avatar
I'll probably bypass it tonight after work then when I get time next weekend I will replace the core and do the blazer motor swap
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 17 Old 06-13-2013, 09:38 AM
Rproject
1987 YJ Wrangler
Mine was doing the same thing. Do you have a/c on your rig? If so, the a/c system has to be unbolted and moved out of the way to get the heater duct out. I never have, nor will I ever, use my a/c, so I took the opportunity to rip mine out. Made the job easier and gave me a spot to mount my CB. LOL
The hardest part I had was lining up the blend door. Dang thing kept wanting to fall to the side as I put the cover back on the duct. Took a couple tries, but I got it to go.
Good luck.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #10 of 17 Old 06-13-2013, 10:22 AM
RobzRidez
Just bypassed mine last night, cake walk! Connector was $2.99, its a 3/4" to 1/2" FYI. Gonna replace the core later and do the bronco blower swap at same time and after reading maybe ripping out the ac system...
90 YJ Islander*Nuttered4.2*MC2150*4" RE Lift*BESRK 1" Boom Shackles*33x12.5x15 BF MTs*Spyder bumper*
RobzRidez is offline
post #11 of 17 Old 06-13-2013, 11:28 AM Thread Starter
Tom95YJ
Tom95YJ's Avatar
Good luck.
I don't have ac. So that's not an issue only sissys need ac in wranglers
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 17 Old 06-13-2013, 11:34 AM
Rproject
1987 YJ Wrangler
Hence the reason I pulled mine.
1996 White ZJ
Rproject is offline
post #13 of 17 Old 06-13-2013, 11:43 AM
idaholtby
Write up for heater core replacement .....
http://www.jeepforum.com/forum/f12/heater-core-219329/
idaholtby is offline
post #14 of 17 Old 06-13-2013, 12:05 PM Thread Starter
Tom95YJ
Tom95YJ's Avatar
Thanks for the link but I've replaced a blower motor on my 95 Yj so I know how it comes out already
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 17 Old 06-13-2013, 12:10 PM
idaholtby
If you are already up to speed on this then great, perhaps then this will help others with the same issue who are reading this thread.
