Is it possible - Page 2 - JeepForum.com
post #16 of 25 Old 03-10-2010, 09:39 AM
SkullTripper
1987 YJ Wrangler
Its a Jeep thing....
My 1987 Jeep Wrangler Build..
SkullTripper is offline
post #17 of 25 Old 03-10-2010, 10:37 AM
gunnorthered
Wow, I've never even seen a shim on a starter. I have had a 93 & 95 L4 and a 94 L6. Is this something that was only done to the 91 and earlier models?
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P.
1993 YJ - Stock 2.5L, Scrapped. R.I.P.
gunnorthered is offline
post #18 of 25 Old 03-10-2010, 10:39 AM
wendell
1987 YJ Wrangler
You can try a hillbilly starter tester. Take a battery charger and hook the ground to the battery caseing, then touch the positive to the stud on the starter where the positive battery cable bolts on. If the starters spins fine, or doesn't grind, it's not the starter.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #19 of 25 Old 03-10-2010, 01:14 PM Thread Starter
Plowhoss
Looks like NAPA is the place I will be going from now on.
Thats where I ALWAYS went then they moved out of my town to another and advanced is the only kinda close now.
Plowhoss is offline
post #20 of 25 Old 03-10-2010, 01:25 PM Thread Starter
Plowhoss
Could the starter be grinding because my stupid cousin left out like 4 transmission bolts?the top two transmission bolt are out and two on the bottom.i'm gonna got to the hardware store and match up threads and put all the transmission bolts in.
Plowhoss is offline
post #21 of 25 Old 03-11-2010, 04:00 AM
dodger889
Yes missing bolts could cause the problem you have. For one the engine and trans are not properly seated. The second the center line is not straight.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #22 of 25 Old 03-11-2010, 05:48 AM
ionakana
Grand Poobah
ionakana's Avatar
I don't know about YJ's but when I replaced the starter on my Mom's Dodge mini van it had a shim on it.
As far as Advance and Autozone, they sell the exact same parts in a different labeled box. Look up parts on their websites, they have the exact same part numbers with maybe a few letters in front of the number added. Napa sells the same parts they do too but do carry some different brands, depending on what I'm looking for I'll go to Napa but always look online to see if I'm buying the exact same part as Autozone or Advance. If so I go to whoever has it the cheapest.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #23 of 25 Old 03-12-2010, 12:05 AM Thread Starter
Plowhoss
Yall I got it fixed she starts up perfect.When I changed the flywheel it had a different teeth count and it took a starter from a 92.
Plowhoss is offline
post #24 of 25 Old 03-12-2010, 12:08 AM
Dado99TJ
Junior Member
Dado99TJ's Avatar
Good work!
Thanks for letting us know what the problem was.
Nightcrew member #331
Blue Jeep Club member #332
Dado99TJ is offline
post #25 of 25 Old 03-12-2010, 12:14 AM
YJake
Originally Posted by Dado8788 View Post
Good work!
Indeed, too many thread sout there that are never ended!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
