positive battery cable - JeepForum.com
post #1 of 4 Old 11-13-2006, 11:14 AM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
I need to replace my positive battery cable on my 94 yj. Is there somewhere I can get one besides the dealer? I can only find the negitive at the part stores, nobody can get the positive. The dealer wants $105.00!!!!! Ouch!!
ionakana is offline
post #2 of 4 Old 11-13-2006, 01:13 PM
brk913
I was able to obtain one from ACME Auto in CT for about $20 (unfortunatley I believe they are only in CT)...none of the "chain stores" like Advance Auto or Pep Boys could get one...I am sure if you go to the better parts stores like NAPA they can get it for you...the problem is the positive cable has 2 heavy gauge wires coming off it, one for the starter and one to the fuse block next to the battery...
brk913 is offline
post #3 of 4 Old 11-13-2006, 01:29 PM
JFM626
JFM626's Avatar
You can also go to a truck dealer or repair shop (Kenworth, Mack etc.) they will be able to custom make one for you, with the pigtail as well. You can also buy battery positive terminals that are solder on. You will need a propane torch with a pencil flame tip, one positive solder type battery clamp, the correct length of battery cable, a length of 8ga wire for the fuse box connection and the necessary copper ends to attach the positive ends to the starter, and fuse box. Get a couple of appropriate sized shrink tubing, some rosin core solder and some electrical tape.
If you are going to make your own I have found the easiest way is to melt the solder into the battery cable clamp and then insert the battery and fuse box wires into the clamp(after you have bared the appropriate amount of wire of course ). Keep the torch on the clamp as you slowly insert the two wires. The solder will flow into the wires as you push it in. Same for the other ends. Oh yeah, make sure you put the shrink tubing on the cable before you solder the last connections on; often they won't go on after.
JFM626 is offline
post #4 of 4 Old 11-13-2006, 01:30 PM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
I don't know what's wrong with me, the bolt on the terminal end has just been eaten through by corosion. Must be Monday brain fog. I just need to replace the bolt, not the entire cable...Brilliant! Thanks for the help though.
ionakana is offline
Positive Battery Terminal hit fender while driving lost all power.. BringThaPain TJ Wrangler Technical Forum 48 04-21-2009 01:40 AM
Where to buy odd battery cable 1993Renegade YJ Wrangler Technical Forum 7 06-13-2006 04:07 PM
Can i put the positive cable to the negative? Nickb1907 TJ Wrangler Technical Forum 12 03-08-2006 06:51 PM
extra cable coming from positive battery wire cueball YJ Wrangler Technical Forum 4 08-28-2005 04:13 PM
Positive battery cable Kev YJ Wrangler Technical Forum 5 04-23-2004 09:21 PM
